the reason i thought it would be the fuel is the fact. When we did a dyno he hooked up wideband sensors and the left bank would lean out. im not sure of the number that it was putting out. i just saw it on the chart and he explained it to me. The fuel pressure guage is reading right where the fuel is coming in so we figured it wouldnt be able to tell what kind of pressure is at the other side of the fuel rail.
The car was tuned after the blower was put on.
As for plugs i have autolite Iridum gapped at .30 and a MSD distibutor, MSD blaster coil, but no igntion box. Have Accel wires.
The MAF is a PMAS calibrated for my 42lbs
so if i gap the plugs smaller you think i will notice a difference?? and if i do then i should buy an ign box?
for there to be a pressure build up near the schraeder valve, the whole fuel rail will have to pressurized with fuel. there is no way to have a pressure on one side of the rail and not the other. if your getting fuel pressure readings via the schraeder valve location i am 99.99999999% sure your fuel rails are filled and pressurized.
as to why one bank is running lean thats very odd and could be alot of things.
do you have a way to datalog the car and view injector pulsewidth on both banks so you can see how they match up? during WOT the EEC goes off the base fuel tables and both banks should be targeting the same AFR. only time you get the two banks targeting AFR is in closed loop where the EEC is recieving feedback from the HEGOS and trimming fuel to stoichiometric according to what the o2s report. during OL the EEC goes off the base OL fuel table which references off load and engine temp.
perhaps your have a gummed up injector not delivering fuel enough to show up lean on the WB.
as for the spark, try lowering the plug gap .010 and run the car again see if you notice a difference. if it helps in a positive way you know its related to ignition. if it doesnt help any at all. then the ignition is fine. but a good ign box is still a good idea. so you can open the plug gap up and get a bigger spark and make more power.
does the car just lean out some and run smooth still or does it actually break up and act like its missing?
i have a problem every now and then with my car where one sides o2 wont heat up, the other will and the car will go into CL. then the EEC starts pulling fuel out on one side and adding fuel to the other. the result is half the motor runnning rich and the other have running super lean. the car will idle and drive pretty bad during this period, once the o2 in question gets heated up and stops lying to the EEC the car smooths up and run perfect.
what i am getting it my engine runs really funny and crappy when the motor runs half rich and half lean, and thats at idle speed and light cruising. i can imagine is would even run worse under WOT load. ( which i couldnt do since the car would go into OL under enough load or WOT) the eec completely ignores the o2s then and targets the base OL table AFRs
