Not running right -- smoking under hard acceleration
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
my car will run normal and smoke free when i keep it under about 2500-3000 rpm, but once i drop the throttle a little harder and let it wind up some more, i get a pretty steady dark smoke... it's not very heavy or ploomy, just smells and its pretty noticable... i know this is common... what should i check?
I_AM_CANADIAN said:
I thought that when you go open throttle, the O2 sensor "shuts off" and the injectors just blast fuel, causing a rich condition, which then causes back smoke?
on foxes, the puter ignores input from the O2's (they still do function at WOT). there is still some fuel trimming going on though. it is on the rich side (vs the SN EEC-IV puters).
I_AM_CANADIAN said:
so then it is normal for some black smoke when under hard accel?
you are correct - it can be normal (relatively speaking). the fuel trim is on the rich side (which is nice. the T4MO puter on the SN's trim a good bit at WOT, which kinda sucks).
