Not Starting - carb?
  • Thread starter Thread starter skywalker
  • Start date Start date May 9, 2010
skywalker
733
Pensacola, FL
May 9, 2010
  • May 9, 2010
Second hand carb, supposedly rebuilt but who knows...
Anyhow, car turns over, fuel is getting to the carb (pump is working) and there is a spark, but there's no ignition.
'66 with a 302.
Carb is an older Edelbrock 1406. I attached it as part of a 2 bbl to 4 bbl conversion.
I have a hunch that there is no fuel going into the cylinders but no way to confirm this. Anyone?
Or any other suggestions as to what I should try?
brianj5600
1,964
Middle TN
May 9, 2010
  • May 9, 2010
Take the air cleaner off and see if the accelerator pump is working. If it is, the problem is some where else. The distributer could be 180* off too.
pabear89
2,126
High in the Hills of So Ca with the Voices in My H
May 9, 2010
  • May 9, 2010
Give it shot of starting fluid, if there is any life in it it will show up.
skywalker
733
Pensacola, FL
May 9, 2010
  • May 9, 2010
Okay, I've tried the distributor and the accel pump is working.
RGS0907
429
New Jersey
May 10, 2010
  • May 10, 2010
You never said if the car ever ran or if this is a new problem since installing the carb.
robbz28
775
Epps, LA
May 10, 2010
  • May 10, 2010
Sounds like your timing is off either a cog or 180 degrees. I had that same problem with my car and its easy to do. Once i got it lined up correctly she fired right up.
skywalker
733
Pensacola, FL
May 13, 2010
  • May 13, 2010
This is new since installing the carb. I haven't tried starting fluid yet. I have flipped the distrbutor 180 degrees to no avail.
robbz28
775
Epps, LA
May 13, 2010
  • May 13, 2010
Now when you "flipped the distributor" i hope you just rotated the engine 180 degrees and reinstalled it....on the compression stroke not the exhaust stroke.
Wicked65
490
NORCAL
May 13, 2010
  • May 13, 2010
YOu might want to start at the basics of finding top dead center, reinstall the dizzy, and try again.
skywalker
733
Pensacola, FL
May 13, 2010
#10
  • May 13, 2010
  • #10
Done...No Dice.
Wicked65
490
NORCAL
May 13, 2010
#11
  • May 13, 2010
  • #11
Did it run at all? or is this the first attemt at starting? Check compression, and if thats fine, then either rebuild the carb, or send it to someone to look at.
woodsnake
1,352
15
69
Hicksville, NY
May 13, 2010
#12
  • May 13, 2010
  • #12
The starting fluid will confirm or deny that it is a fuel issue.
A no start is a simple check list thing. Battery charged? Gas in tank? Power to starter? Spark at distributor? Spark at cylinder?
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 11, 2026
roldy
R
H
Starting
  • Howza289V8
  • Apr 7, 2024
1965 - 1973 Classic Mustangs -General/Talk- Apr 8, 2024
Howza289V8
H
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
