  • 1994 - 1995 Specific Tech
not starting question
  • Thread starter Thread starter stang723
  • Start date Start date Feb 15, 2004
stang723
163
houston, texas
Feb 15, 2004
  • Feb 15, 2004
Well im confused, because my car had to be jumped last night, i sorta figured it was the voltage regulator, cuz its a brand new battery. There is enough power for the lights to shine bright, and my stereo to play, but the motor just wont start, anyone know what it is??
2L8ULUZ2
Will kiss Moderator ass for title
3,033
14
99
WNC
Feb 15, 2004
  • Feb 15, 2004
Will it turn over or just click? First I would get the battery tested since it will jump off. I know that it is new but that makes no difference with batteries. I have seen them go bad in a couple days in cars. Get it tested and then when there is either a charged or new battery in the car have the alternator checked. Most places like autozone or advance will do both for you for free. The problem you are describing sounds like a amperage problem. The lights and all just need 12v to operate. The starter requires quite a bit of amperage to operate properly and start the car.
stang723
163
houston, texas
Feb 15, 2004
  • Feb 15, 2004
Well also a few weeks ago, my battery went out, and its an interstate, so i used there really good warranty, and just traded it for a new one, so i figure its not just a battery?
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Feb 15, 2004
  • Feb 15, 2004
Like said before, a new battery doesn't constitute a working battery. What is your car doing? Will the starter crank the motor when you turn the key? Or do you get clicking?
If you get clicking, the battery is not holding a charge. So either the battery is bad, or your alternator is bad. Go to autozone, and have them tested. Simple and easy.
stang723
163
houston, texas
Feb 16, 2004
  • Feb 16, 2004
yea, i the alternator tested fine, and the battery IS bad, so i replaced that, and also, my battery cables had a bad connection, so i got new ones, but what would have drained the battery in the first place? Because this is two new batteries in like two months!
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
T
2001 GT 4.6 V8 weak crank no start.
  • The-Bamboo-Farmer
  • Nov 12, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 13, 2025
The-Bamboo-Farmer
T
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
  • dan50
  • Jul 18, 2026
dan50
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
