I dont know where its comming from. It seems like everytime after I take my car on the highway my rear bumer/trunk lid gets sprayed with some dark fluid. I dont know if its my rear main seal blowing oil back there or if it is my rear end.
I just replaced my diff. cover with a T/A cover. After doing it 3 times myself I finally sent it to a shop. It kept leaking on me. After a few times at the shop they realized that the breather hole (tell me if this is B/S because I need to know if Im getting screwed) was rusted shut- limiting venting and causing excess rear axle pressure.
I am laying off my car until I get some replies from you guys and you guys only.
I hear gear chime-for a while its been only when im in low rpms in 6th but now its in the low rpms in 5th (below 2500rpms near a jersey barrier or hard wall). It is a whining noise, thats the best I can describe it.
I am doing an oil change this week, I also will be checking the rear end out-specifically measuring the rear end fluid level. What else should I check?
Also when I go around corners there is a choppy noise-leading me to believe that the rear end is at fault.
However when I shift gears the gear shifts are choppy. Sometimes I need to really slam the shifter into gear. Could this be two problems in one?
I really dont want to have trany problems-this one killed my bank account. However if its my rear end its a little bit better. I didnt want to do any more mods to the rear end but if its toast then whatever...I'm going to have to suck it up.
Please post up fellas, I need your help!
