notchback question
bills93notch
18
can one of you notch owners tell me when you look into the trunk and at the back seat do you have any covering on the seat itself or do you see the yellow foam from the seat. someone installed 12 inch speaker mounts on plywood and i want to remove it but want to make sure the seat back is recovered if supposed to be
There should be a layer of sound-deadening material between the back of the seat, and the cross bracing. The top of the material attaches to the top cross brace, hangs down, and runs under the seat bottom. There were slots cut in it for the hooks on the top of the seat back to go through.
The original material is sandwiched between two layers of thin, black plastic sheeting (similar to a thin plastic trash bag). It's also used behind many of the interior panels. I replaced mine with this "Super Insulator Mat" from Summit Racing. It has better insulating qualities than the OEM stuff.
