now what?
5.0convert88
47
palatine IL
ok so today i changed my spark plugs and thats all. i tryed cranking the car in its not firing its just cranking, i sounds like it wants to go but its not. i went over all the wires and checked the fireing order 3 times and still nothing . wat can it be ?
TFI sensor. It's mounted on the side of your distributor. Unscrew the bolts ond pull down.
Before you go buy one you might want to search for a "cranks Ok but no start" checklist on this site. It will give you a dozen possible promblems to check.
are you getting spark at the plugs...you will have to remove one and hold the threads against a ground the header will do and have someone turn motor over keep hands free of any thing in case it cranks and be careful where you hold the plug so you don't get shocked wear a glove if you have one...and look for a spark while cranking and post rusults....and is coil wire attached...simple things are easily overlooked...
HERES A PIC. OF THE FIRING ORDER AND ENSURE THAT THE #1 PLUG WIRE IS PLUGGED INTO THE CAP WHERE YOU SEE THE 1 STAMPED ON THE CAP....
If all you did was spark plugs, then the only thing you could have done is put the wires back on wrong. This is why you ALWAYS do them one at a time. :nice: Only other thing is you might have not gapped the plugs and they're all or most are either completely closed or way too open.
Nick
