nuts, bolts, and brackets - MISC
NFGTragedy
155
Rochester, NY
So i've come very far through my 4cyl to 5.0 swap and i am now stuck finding some bolts sizes and stuff... here is my list... feel free to chime in with sizes, threads, bolts, whatnot...
bolts that mount the rear shocks to the rear end... any ideas?
motor mount bolts... i swapped my stock broken ones for new ones and the bolt is a little more skinny then the original... any ideas?
bolt to mount the steering shaft to the rack... its up right before the u-joint up near the firewall... any ideas?
front bolt that holds the passenger side seat in... threads through the floorboard... any ideas?
front sway bar brackets... originally mine had i believe a plastic thing holding the top nuts on... when i impacted it off it broke... should i go to ford and get a new one or buy some bolts and just hold them with a wrench?... also bolt sizes and length would be appreciated...
also if anyone knows a good belt size to run a serp belt with nothing deleted and with ud pullies let me know... the guy at the store sold me a 105 and its ****ing huge... dick.
anyways your help and info will be appreciated. Thanks in advanced. :SNSign:
This is hard because some of these have changed over the years, and because replacement stuff is different yet.
Rear shocks have at least two mounting styles, single bolt and clevis. My 89 LX had single bolt. I think it's metric, but it has a torx head and nut with a tag on it, so any similiar size would work. I would prefer one with a hex vice the stock torx.
Motor mounts are different. The 5.0 block uses 7/16 bolts, I think, but thats easy to find by trial and error. Frame side I am not sure... I have two sizes on two cars....
I think the steering intermediate shaft bolt is metric, not sure what size, but a similar grade 8 ought to do.
Front sway bar mounts vary widely over the years. I have early ones with the nuts welded, and some later ones with loose fit nuts, and all are metric I think.
Bottom line, you will need to try most of these on your car to see what fits, my best suggestion.
