I've had my electric fan for about 3 weeks and I got some problems. The fan works great, but I am using the red/green stripe wire that runs from the ignition coil as the power when running.(I think thats where the wire is from) When I turn the key to the on position the fuel pump comes on as usual, and the fan comes on and keeps running, then i turn the key to start, it works as normal. I am not good with wiring diagrams, so I am asking if someone could tell me EXACTLY which wire i should use and where, so the fan comes on only after the engine is running.
