O Please help!!!!
I'm still lost as to why you have mils on your X-pipe. Any aftermarket catted midpipe is only gonna have 1 cat per side. If your UN-catted, then you need the mils. Otherwise I would just ditch the mils and just put o2 extensions on and it should run fine. I've never thrown any code with my catted midpipe with just o2 extensions. Does it specifically state with the SLP catted midpipe that you run mils?
It will occasionaly happen with high flow cats. The MIL's are a cheap fix.
He shouldn't need O2 extensions either since he has an '03.
I am running an aftermarket catted H-pipe and have never thrown any codes since installing it over three years ago. If I did, I would go the flash tuner route because with the exhaust mods, he may be running somewhat on the lean side.
