O2 Question
O2 Sensors just provide feedback to the ECM about the engine running rich or lean. I don't think a bad or dirty O2 sensor would cause a surge during acceleration, rather just run more rich or lean than it should. Your best bet would be to pull the codes and see what the ECM think's is going on. Jrichker has a good post on how to pull the codes using just a jumper wire or paperclip.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
index.php
index.php
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
attachment.php
89 through 95 cars have a working Check Engine light. Watch it instead of a test lamp.
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
What year of stang do you have? If it's a 94-95, there have been instances reported where a bad O2 signal caused surging. It seems to be much less likely on a fox (the foxes run rich in FMEM and 5N's run lean).
Good luck.
