O2 SENSOR WILL NOT COME OFF!!! HELP!!!
MoNsTaMaCk24
742
Shippensburg, PA
It isnt coming off... I dont care what anyone says... I got the one side off... this side no way... I broke the o2 so then i got a regular socket on it... 1/2 inch 2 foot breaker bar...Thing wont come off... Any ideas???? All help appreciated!!! I tried wd40 and bangin it with a hammer and also praying to lord... none worked....
PB Blaster is a high grade penetrating oil. WD 40 is a lubricating oil. You need PB Blaster or Liquid Wrench (penetrating oil) to get that sensor out. Spray it on, let it sit for a while (say, 15 minutes), give it a second spritz, let it sit (15 minutes more), then try.
Good luck.
Are you taking off your H-pipe? If so you can probably just disconnect the electrical connector and then remove the pipe. Then you can get a bit more leverage to remove the sensor since you won't be under the car. If you aren't removing the pipe then I guess I don't really know what to tell you. I just used a breaker bar to remove mine.
I ran into the same problem. Liquid Wrench worked for me.
Removing the O2's was probably the most difficult task when I helped remove my friend's H pipe. Now, when I swap out my cars OEM H for something better, everything will get Liquid Wrench'ed
