  • SN95 4.6L Mustang Tech
o2's
  • Thread starter Thread starter steveb24
  • Start date Start date Feb 14, 2006
steveb24
555
wilmington, DE
Feb 14, 2006
  • Feb 14, 2006
what do i do with the 4 holes on my prochamber where the o2's should be?..i already had the o2 sensors turned off when i got my car tuned. the prochamber came in and im ready to put it on. thanks
bham_gt
94
Birmingham, AL
Feb 14, 2006
  • Feb 14, 2006
Even though you had the rear o2 sensors turned off, I think you still need to plug them in, even if for nothing more than filling the holes. Of course, the front ones still need to be plugged in because they should still be working.
M
Mindstatic Pro
107
INDY
Feb 14, 2006
  • Feb 14, 2006
You can buy plugs to fill the holes. Check your with your local exhaust installer, Midas or anyone similar should have them and they're MUCH cheaper than O2 sensors.
Along the same lines....I installed a Bassanni catted x and do not know where the fronts plug into. There are two female ends underneath the car right next to the rear O2 bungs but nothing around the fronts. I had no loose ends when re-installing the wiring harness and have no idea where the fronts plug into. I was told that you dont even need them.....is this true???
All four of my O2 bungs were filled w/ the plugs....
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Feb 14, 2006
  • Feb 14, 2006
no you need the fronts. the connectors for the frt 02 hang on a bract mounted at the top of the transmission. the connectors themselfs are up at about the height of the stock manifold flange but inward toward the transmission. look up there with a flash light you will see them
trailblazr81
571
Hollister, Cali
Feb 14, 2006
  • Feb 14, 2006
Put the fronts in!!! The rears, either your old O2's or plugs. I just re-used the O2's and connected the wires to them even tho they are turned off.
bakos24
I find there is nothing better than a tasty wiener
87
134
NE, OH
Feb 14, 2006
  • Feb 14, 2006
Yeah, you need the fronts in. For the rear just reuse the stock O2s. even though you dont need them just go ahead and put them back on. that would be the easiest thing to do.
M
Mindstatic Pro
107
INDY
Feb 14, 2006
  • Feb 14, 2006
I dont remember seeing the front O2 plugs before dropping the new motor in. They must be there though. Ill have to fish around for them. Any suggestions on the cheapest spot to find new sensors?
jivepepper
776
Under a Sombrero. in WV.
Feb 14, 2006
  • Feb 14, 2006
How does your car even run correctly?
M
Mindstatic Pro
107
INDY
Feb 14, 2006
  • Feb 14, 2006
I couldnt say how it still runs but it seems to be running strong. I have only driven the car 20 miles since the install (to and from the exhaust shop). I still dont have a new front bumper and its not being driven until then. I wont fire the car until some O2's have been installed. I was told by my exhaust guy that you will just lose some HP and MPG. No major consequences but definately worth the purchase.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
  • Gulftown980x
  • Jul 29, 2026
squeak93
