OBDII code help
mdmike
Hello, I’m new at this, so please bear with me if this is incorrect. Hopefully someone can help answer these questions for me, so I can save a little $$. I can turn a wrench, but don’t claim to be a mechanic. I looked in a Haynes book, but it’s not detailed on causes. I have 2 OBDII codes on my 1996 Ford Mustang Cobra. One is, P1445 Purge Flow Sensor circuit Input High. I can't find anything on it for my vehicle. What part and where it is located on the car? Where can I get one?
The other code is P0411 Secondary Air Injection System Flow Improper. I can't find anything about this code either. What could it be? Where do I find the parts and where are they located if the problem is identified? I found info on the purge flow sensor on your forums, but not specific to my vehicle. Where is it located and where can I get one?
not sure if it is different but on my car it is on the passenger side back side of the motor. You should be able to get parts at the dealership. If I am not mistaking that is a evap code it may even be a leaking vacuum hose or loose gas cap. Check the vacuum hoses going to the purge canister first.
