  • SN95 V6 Mustang Tech
Octane Adjustment Bar?
  • Thread starter Thread starter HyYoSilver
  • Start date Start date Jul 17, 2006
HyYoSilver
1,339
On a creeper, underneath the car
Jul 17, 2006
  • Jul 17, 2006
My 92 had one that I removed to alleviate spark knock. It was a wiring harness plug-in located on the passenger side firewall. Does a 94 have one? My daughter's 94 3.8 has developed a spark knock when going up hills, and I thought that would be a quick fix if it's indeed equipped with one.
While doing a search, it seems that the PCV system gets clogged and sends excess oil into the intake.....? Would installing a new PCV valve and cleaning the hoses help with spark knock?
Thanks,
HyYo
Adverse2Change
340
Raleigh, NC
Jul 18, 2006
  • Jul 18, 2006
Is it an auto or manual? On manuals, just down shifting will usually eliminate knocking going up hills. Cleaning the entire intake system will help temporarily, but knocking will eventually come back. Your best bet is to up the octane if it gets really bad.
HyYoSilver
1,339
Jul 18, 2006
  • Jul 18, 2006
Thanks for the reply, NCSU. Yeah, it's a manual, and the pinging is getting worse. I plan on checking the EGR and PVC systems this weekend; maybe clean up everything and install a new PVC valve.
If that dosen't help, guess I'll take your advice and go up a grade in gas and see what that does.....
ChrisYellowV6
362
Pensacola, FL
Jul 19, 2006
  • Jul 19, 2006
Here's the thing... i think your 92 probably had fuel injection not a carb, i know the 94 does. The reason people used to go to higher octane gas is because the carbs would get knocked out of whack and let too much air in, and a higher octane gas requires more air in the chamber to ignite the same amount of gas. on fuel injection cars, it is unusual for the air/gas mix ratio to get out of sync, but sometimes the injectors get clogged. I would first try cleaning the injectors and if that doesnt work look into getting them replaced. That's probably where your problem lies.
HyYoSilver
1,339
Jul 21, 2006
  • Jul 21, 2006
Thanks Chris. I'll try some injector cleaner in it too.
A
Resolved 03 GT Parasitic Draw Fuse 26 (PCM)
  • Antrix
  • Mar 22, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 24, 2025
89ripper
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
6K
Other Auto Tech Jul 28, 2024
manicmechanic007
J
1995 Mustang V6 - Cyl #3 Misfire - Help!
  • JasonBlue
  • Aug 30, 2023
  • 1994 - 1995 Specific Tech
5K
1994 - 1995 Specific Tech Oct 20, 2023
def_68
D
Electrical Cylinder 4 Misfire
  • paddyrk
  • Oct 11, 2021
3K
SN95 4.6L Mustang Tech Oct 12, 2021
paddyrk
T
What's it Worth? 1989 GT - What's it worth?
  • Tim83
  • May 11, 2021
  • What is it Worth?!?!?
3K
What is it Worth?!?!? Jun 3, 2021
Mustang5L5
