Odd Ticking Sound - Help!
Hello. I've posted about this issue on other forums, but I'm trying to get as much input as possible.
I drive a 90 Mustang GT and recently it's been making an alarming ticking sound.
What happens is this:
As I approach 1700 RPM, more often than not a sound emerges from the engine that I can best equate to a woodpecker hard at work at putting a hole in a tree trunk. Once I round 2000 it immediately goes away. This can happen through all of the gears, and only during that small RPM range.
I thought it was knock at first, but I've heard other cars ping in the past and they tend to produce more of a hollow metallic sound than a tick. But, I'm still not ruling out that possibility entirely.
I haven't been able to duplicate the sound while in neutral. It only seems to occur while the car is in gear and accelerating. Also, it *only* occurs once the car has been warmed up and running for a few minutes. It does not happen at all when the car is cold or just recently started.
I've tried checking the timing, it's fine. I'm running 93 octane. I've tried unhooking the EGR sensor and plugging the vacuum. Nothing thus far has worked.
Thanks for any suggestions.
) can cause a ticking sound very similar to what you have described.
