Odd transmission noise...
dz187
65
Arizona
I was just sitting in my car, idling in neutral when I noticed a faint sound coming from the transmission. I stuck my ear to my MGM shifter and could hear what I can only describe as rocks tumbling. The sound is very quiet, but it's there. About a month ago my throwout bearing went, so I had a new clutch put in, havent had a problem with it. All I can think of is if the mechanic put new fluid in the transmission, he used the wrong type, or not enough. I put new fluid in the T5 sometime around sept/oct and I used Dexron III/Mercon, so if he didnt touch the fluid it should be fine.
What could this noise be?? :shrug:
that could be alot of things....I bet you could hear the smog pump or the fan from the all metal shifter cause the noice would travel through everything pretty easy...But I would drain the trans fluid and inspect it and fill it back up with new fluid
that is normal. mine does it too. i forgot what it is called but it normally happens when the motor is idling really low due to a cam change. when rpms are a little higher it goes away.
