OKay, I have a 94 5.0 Mustang and the Odometer and closck do not work. Everything else does on the dash (speedometer, tech, gauges all works) Any idea what I can look at? I checked the fuses and they are okay.
For the odometer if your speedo works, it is likely the gear inside the gauge cluster that is broken. Do a search and you can find more info on this and where to order replacement gears and how to check this.
For the clock some times they die, it should have power with the key ON or in ACC. I believe it is only a 2 wire connector if so just test it with a test light with the key in the correct position if your test light comes on the problem is with the clock itself. (good luck finding one in a yard, or used, ford may have them but expect to pay to much)
After you check the clock for power at the connector, if it checks good and you want a clock, I just pulled mine out of the car. I would sell it to you. PM me if you are interested.
