Off idle stumble
  • Thread starter Thread starter steel1212
  • Start date Start date Sep 30, 2005
First Prev 2 of 2
steel1212
1,180
Frankfort, Ky
Sep 30, 2005
#21
  • Sep 30, 2005
  • #21
This is a instant WOT situation. I'm not going to sacrifice upper rpm performance just to fix this aggrivation. My throttle response at the upper rpms is pretty good but I haven't really played with the springs much though.
10secgoal
2,801
San Diego
Sep 30, 2005
#22
  • Sep 30, 2005
  • #22
Fixing this problem is not going to affect your WOT at all. Pump cams are a great investment. The primary squirters aren't too hard to tune for, and are usually pretty damn close out of the box. It's usually going to be the secondaries that cause the problems. I would do what Brian said first. A different spring to open the secondaries a smidgin' later ought to do 'er good. f the car still starts, keep bumping the timing up. You will just have to knock the limiter in the dist. up a few sizes. Right now, and when I had the bottle, I was running 18-22 initial. And had the total at 38-42. The car will be a completely different animal when you compare 13 intial to 18. Throttle response is great. The higher you go with timing though, the more fuel you will need. And you may find when you go to the track and race, it will need more on than on the street. When you hook at a track, it creates a much bigger load on the motor......= more fuel.
thehueypilot
1,084
Medina,Tennessee
Sep 30, 2005
#23
  • Sep 30, 2005
  • #23
Try using the purple or plain steel spring in the vac. sec. Maybe the orange colored cam in the #1 position with #28 squirter.
steel1212
1,180
Frankfort, Ky
Oct 1, 2005
#24
  • Oct 1, 2005
  • #24
Ok guys thanks. I'll try what was suggested. I just ordered a set of vacum secondary springs as well as the pump cams and I'll see if I can't get this worked out.
mfp4073
387
Hells Ditch, FL
Oct 1, 2005
#25
  • Oct 1, 2005
  • #25
My first thought was the pump cam too.
First Prev 2 of 2
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
