Well im tired as hell and i bet my writing will look all funny when i read this tommorow....but anyways went to the track tonight.....First pass, 100 shot slicks, Pulled a 1.9 60ft......bogged hard near the 1/8th marker. Second pass, my overflow bottle cap popped off and laid a nice slick down the full 1/4. But same results 1.9 60ft, bogged. I was low on gas, put some 108 race in there and fixed the bog.....3rd pass I gun it....all is well no bog, about 1/8 marker i get a loud snap, (sounded like a carb backfire) and my cockpit immediatley got filled with a poof of white smoke. The smoke came up through the hole under my megashifter. Pull around and get my slip.....1.9 60ft again......Engine is running real rough. Pulled the plug wires one at a time each made it worse except for 2 and 3. Not sure if I melted a plug or not....Didnt have any required tools (doesnt that always happen). Soo ya taking off at a stop it boggs hard...sounds like its real bad on timing...gradually there is a light tick that dies away, and the car gets up to speed. On the highway it holds its own.....(yes i did limp home). Oil pressure and temp all fine. Tair down time tommorow. Any thoughts? best run i did was a 13.1 at 99 with a 1.9 60ft....and with this i cut off right at the 1/8th.....Thanks fellas
Mike
seemed everyone was off pace tonight.....humidity could have been an issue.
Mike
