  • 1994 - 1995 Specific Tech
Off road h pipe that fits good??
  • Thread starter Thread starter ChrisA#5
  • Start date Start date Dec 2, 2005
C
ChrisA#5
60
Indianapolis
Dec 2, 2005
  • Dec 2, 2005
I had a BBK o/r h pipe on my last car, and the fit was horrible. I like the sound of it, but if theres not one that fits like it should I may get a Mac pro chamber, or Dr. Gas o/r x pipe. Any of you guys have any suggestions on any other brands of h pipes? Thanks Chris
ej95cobra
82
Southeastern PA
Dec 2, 2005
  • Dec 2, 2005
I'm not sure the brand is going to make a difference. I have a BBK O/R H-pipe & a Mac with cats. The fit for both was awful. I found one side hung lower than the other when I could get them connected. What I ended up doing was actually cutting the H connector pipe and using a pipe connector from autozone to allow adjustment of each side. I think the connector was 2 1/4" inside to 2 1/4" outside diameter. On the Mac I also had to cut the small diameter cross pipe and use blue tubing to make the connection. Doing this made the pipe adjustment possible. Remember not to tighten any of the nuts all the way until you have all the connections made, then start on one side front to back, do the other side, then the connector pipe(s). I also use a jack and short 2x4 by the H pipe to cat back connection to keep the pipes up as I tighten the bolts.
94MustangGT5.0
288
Champaign, Illinois
Dec 2, 2005
  • Dec 2, 2005
Mac Prochamber
Fit
Sound
Overall
Z
z400master03
  • Dec 2, 2005
I just installed a summit o/r h 2 weeks ago. Paid 115 shipped for it. Fit was good except the air pump tube? it was a pain would of only took a half hour start to finish without that little tube giving a headache. Also i have no other mods to my exhaust beside flowmaster super 40's which are welded into the stock catback.
C
ChrisA#5
60
Indianapolis
Dec 2, 2005
  • Dec 2, 2005
thanks guys! i may have to check in to that pro chamber. ive never heard one in person (and no computer speakers), but have heard theyre pretty decent.how does it compare to the h (w/ 2 cam flows)? might have to try something new. i'll check out the summit h too, thats a good deal.
thanks ej95cobra-will remember that if i get a crappy pipe again.
ProKiller
3,064
15
78
PA
Dec 2, 2005
  • Dec 2, 2005
i have a full MAC setup. fits pretty well, adjusting the tail pipes is the only problem usually. i did have a mac h-pipe (no cats) with 40 series flows on my old stang. i loved the sound. i never had a problem with fitment.
droptopford 5 0
427
Dec 2, 2005
  • Dec 2, 2005
i bought a mac h last spring and fitment was fine, bolted up to stock headers and mac cat back fine with minimum alligning issues, maybe they've changed the style of them since you bought yours since it comes in three pieces now, allowing for some decent adjustment....
legalize420
1,541
South Florida
Dec 2, 2005
  • Dec 2, 2005
prochamber
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
Dec 2, 2005
  • Dec 2, 2005
Used to have the BBK LT's with BBK o/r H-Pipe anf Flows. The Fit was ok but not that great. Had to modify the H-pipe to make it fit though. Basicly spread it by like 2-3 inches on the headers side. Then I sold all the mods and this setup. Now I recently bought a MAC o/r H-Pipe and the fit is better. Actually it is pretty good. Straighter under there. Only thing is that it didnt bolt directly on the Flows. Had to make (2) holes on the flange a little bigger to accept the Flowmasters. Sound is exactly what I like to hear from a mustang. I recommend it and it is pretty cheap also.
TheDamned
"I am Canadian and Damned for it!"
Jul 22, 2003
457
Montréal, Québec, Canada
Dec 2, 2005
#10
  • Dec 2, 2005
  • #10
Have the mac o\r h-pipe and didnt need to do anything, it fits like a glove!
Black95GTS
1,644
Marlborough, MA
Dec 2, 2005
#11
  • Dec 2, 2005
  • #11
I have a full mutt of an exhaust, MAC headers, BBK OR X, and Flows... fits right on there.
I think it all depends on what day of the week your part was made... mondays and fridays sucking and tues-thurs being spot on.
Adam
C
ChrisA#5
60
Indianapolis
Dec 4, 2005
#12
  • Dec 4, 2005
  • #12
thanks for all the suggestions. i always had a kind of bad opinion of mac stuff, just going off what i was hearing. but from what you guys are saying, sounds like its worth buying
CManT1914
3,172
Killeen, Texas
Dec 4, 2005
#13
  • Dec 4, 2005
  • #13
I might be a little late, but my MAC o/r h-pipe fits pretty decently. Even the smog tube hooked up without any trouble. The only complaint I have is the driver side pipe knocked against the transmission crossmember. I simply wrapped it in some thermo-tec exhaust wrap, and it hasn't knocked ever since. That was over a year ago.
M
Off-road h pipe
  • MadMatt7
  • Oct 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Tuesday at 11:11 AM
nickyb
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
Will a 98 gt off-road pipe fit my 03 gt?
  • Stangman 70
  • Mar 20, 2025
1996 - 2004 SN95 Mustang -General/Talk- Mar 27, 2025
89ripper
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 19, 2026
squeak93
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
