Off to do the balljoints... Any tips?
  • Thread starter Thread starter Papageof
  • Start date Start date Mar 19, 2006
Papageof
322
Jacksonivlle, FL
Mar 19, 2006
  • Mar 19, 2006
The inside edge of my tires have worn down and I get a loud pop when I turn and go over a bump (like at the end of the driveway), so I am heading out to change the ball joints. Any tips?
Papageof
322
Jacksonivlle, FL
Mar 19, 2006
  • Mar 19, 2006
So, I just noticed that my balljoints have neither grease fittings or wear indicators( that I can see) All they have is what looks like a rivet in place. Or, is that the wear indicator, and they are just that worn
94_Teal_GT
405
Palm Bay, FL
Mar 19, 2006
  • Mar 19, 2006
To answer the first part of you question, borrow/rent/buy the right tools for the job
Ball joint press kit $19.99 Note: If you decide to buy that kit, you will have to print that internet price or they will charge you $39.99 for the kit at the store.
This should be available from Harbor Freight as well. I paid under $10.00 for mine.
I'm just not a fan of using a BF hammer when the right tools are so cheap. Do not remove the nut completely, that way when you use the pitman are seperator the suspension doesn't fly apart.
Papageof
322
Jacksonivlle, FL
Mar 19, 2006
  • Mar 19, 2006
Thankx, I am actually gonna rent that from AZ now. I might buy one later. Between the tires, and the BJ's, bearings, rotor turning, and shocks this is gonna take my entire paycheck.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Mar 19, 2006
  • Mar 19, 2006
Here's a great and quick little read I keep in my favorites.
http://members.shaw.ca/Notchmustang/Balljoint.html
Papageof
322
Jacksonivlle, FL
Mar 19, 2006
  • Mar 19, 2006
Well, I decided to hold off until tommorow. I think I am gonna change the springs at the same time. I just can't get them until Monday.
--What are the odds I will be able to get a decent alignment using FMS-B springs on an otherwise stock suspension?
Thank you DMAN, I had seen that site years ago and forgotten about it.
Paully's5.0
495
WI
Mar 19, 2006
  • Mar 19, 2006
Somthing I found useful, when you are putting on your new rubber boot around the ball joint, make sure you pick up a piece of 2" round exhaust pipe, I found an adaptor for $1-$2 at the local hardware/autoparts store that did the trick. Place this pipe around the rubber boot and it will allow you to use a mallet to carefully put the boot on. This ensures that it goes on evenly and you won't rip the boot in the process.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Mar 19, 2006
  • Mar 19, 2006
You may want to consider a good set of C/C plates to go along with everything you are changing!
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
  • Mindseye007
  • Aug 16, 2026
Mindseye007
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
