  • SN95 4.6L Mustang Tech
Official Tremec 3650 Issues Thread
  • Thread starter Thread starter Twisted
  • Start date Start date May 27, 2003
  • 79
  • 80
  • 81
  • 82
  • 83
  • 92
First Prev 81 of 92 Next Last
J
jdgt281
20
Florence, Alabama
May 30, 2005
#1,601
  • May 30, 2005
  • #1,601
Tranny
My car is a 2003, I bought it new in late 02. At 12k the tranny started grinding third and fith gear. for replaced the whole trans. After the warranty ran out I broke three shift forks and three secronizers and two shift pads. Needless to say I thik you guys are correct when you say they all have problems.
dsg_gt2004
423
Georgetown,SC
May 30, 2005
#1,602
  • May 30, 2005
  • #1,602
git-it-83 said:
I have missed 3rd even with my Pro 5.0 at higher rpm's. Mid rpm and mildly aggressive shifting are OK, but under rapid conditions my pony does not like 3rd....
get it fixed ..maybe your synchros...i used to think that it was normal when i would occasionally miss 3rd with my tri-ax, but i recently had ford fix my tranny and i havent missed once...i actually chirp in 3rd now...
M
mussang
52
ohio
May 31, 2005
#1,603
  • May 31, 2005
  • #1,603
Breaking 3 shift forks and 3 synchros is not atrans problem , its a driver problem. You will never fix that at a dealer unless you sell it . They make autos for drivers like you( and my mom). The shift probles here are not what you describe.
psnous
285
Blue Springs,MO USA
May 31, 2005
#1,604
  • May 31, 2005
  • #1,604
kevsstangs said:
Hey Psnous, im the guy in kc with the yellow 01cobra conv. so i should just get the rebuit kit cause if its not much cheaper than a new t3650 i might just get a new one. Do you have any suggestions on were to get labor done.
For a tranny swap call Mike's Performance at 694-0099, ask for Mike. He may be able to do a rebuild also but the parts are expensive
K
kevsstangs
#1,605
  • May 31, 2005
  • #1,605
thanks psnous ill give him a call about a swap. Im thinking im gonna put a new tranny in.
Cobra Jay
889
Motor City
Jun 8, 2005
#1,606
  • Jun 8, 2005
  • #1,606
Twisted
387
Hansen,CT
Jun 8, 2005
#1,607
  • Jun 8, 2005
  • #1,607
Quick summary for any new comers. 1-2nd grind. Service bulletin for fluid level doesn't really help. TSB syncro/gear cluster rebuild kit really makes an improvement, but not 100%.
hauoli63
178
Northern Virginia
Jun 8, 2005
#1,608
  • Jun 8, 2005
  • #1,608
Right on! Definately not a 100% fix!!
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Jun 12, 2005
#1,609
  • Jun 12, 2005
  • #1,609
what years are affected? all 3650s?
hauoli63
178
Northern Virginia
Jun 12, 2005
#1,610
  • Jun 12, 2005
  • #1,610
Link
bigcat
May 1, 2005
3,015
7200 feet
Jun 12, 2005
#1,611
  • Jun 12, 2005
  • #1,611
sounds like alot of the same things that i described to the service dept. about my 05 gt.....
dsg_gt2004
423
Georgetown,SC
Jun 12, 2005
#1,612
  • Jun 12, 2005
  • #1,612
try this, hold your clutch in and try to shift from 1-2 fast, 2-3 fast, 3-4 fast, 4-5 fast...now if any make a grinding noise, you will be able to have it fixed easily...all you will have to do is take a tech on a ride with you and show them that it grinds in whatever gear..that's what i did and they rebuilt my whole tranny
it was a 100% fix and it feels 100times better than the first day i bought it
M
mussang
52
ohio
Jun 13, 2005
#1,613
  • Jun 13, 2005
  • #1,613
The mis information tha spews from this thread is amazing. If you depress the clutch and get a clash when shifting the only explanation is that the clutch is not releasing. The 05 is a completely different release system. It is a hydraulic system that is known to require a careful bleed operation when a poor clutch release is experienced. The older mechanical, cable system can also be mis adjusted to not fully release the clutch . The TSB for 1-2 shift concerns has nothing to do with 3-4s or4-5s.Or 05 MY cars for that matter.
Cobra Jay
889
Motor City
Jun 13, 2005
#1,614
  • Jun 13, 2005
  • #1,614
You are right. The TSB doesn't even cover 04's, but dealers are fixing them though.
The TSB is for 1-2 and 2-3 synchros and sometime reverse if it is damaged.
F
four.six
443
Corpus Christi, TX
Jun 17, 2005
#1,615
  • Jun 17, 2005
  • #1,615
i am also getting a grind from 1st to 2nd.... hopefully ford sees this thread and actually does something about it. but i doubt it......
hauoli63
178
Northern Virginia
Jun 17, 2005
#1,616
  • Jun 17, 2005
  • #1,616
Ford has done something about it ... they created a TSB ... have you taken your's in to get the fix? ... but, you are probably out of the warranty period, huh?
F
four.six
443
Corpus Christi, TX
Jun 20, 2005
#1,617
  • Jun 20, 2005
  • #1,617
yes i am out of warranty... what is this TSB u speak of??? and where can i get it at??
hauoli63
178
Northern Virginia
Jun 20, 2005
#1,618
  • Jun 20, 2005
  • #1,618
TSB = Technical Service Bulliten
Here is a Link to a copy of it
F
four.six
443
Corpus Christi, TX
Jun 21, 2005
#1,619
  • Jun 21, 2005
  • #1,619
my car does have the tremec 3650 right??
M
mussang
52
ohio
Jun 21, 2005
#1,620
  • Jun 21, 2005
  • #1,620
Yes ,all 01 Cobras. There was a mix for the GTs between the T45 and the 3560 for '01.
  • 79
  • 80
  • 81
  • 82
  • 83
  • 92
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Thursday at 7:46 PM
JMG9350
J
Shifting Issues - Tremec 3650
  • KingCobra2001
  • Jul 13, 2005
  • SVT Tech Forum
3K
SVT Tech Forum Jul 13, 2005
COBRA90GT
