Offset Question
  • Thread starter Thread starter dz01
  • Start date Start date Apr 15, 2017
dz01
285
10
Massachusetts
Apr 15, 2017
  • Apr 15, 2017
I see a lot of wheels have an 18mm offset. Mine are 16mm. Does that mean the 16mm is closer to the car or pushed further out? My backspace is 5.75"
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Apr 15, 2017
  • Apr 15, 2017
16mm positive offset would be closer to center line of wheel than 18mm
General karthief
Mod Dude
Aug 25, 2016
28,133
10,750
213
polk county florida
Apr 15, 2017
  • Apr 15, 2017
The basics: The offset can be one of three types (measured in millimeters).*
ZERO OFFSET
The hub mounting surface is even with the centerline of the wheel (dashed line to left).
POSITIVE
The hub mounting surface is toward the front or “wheel side” of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars. An example of a positive offset wheel is the Polaris RZR 1000 which comes stock with a +38mm offset. Higher offsets restrict design and leave the wheel looking flat, with little to no depth in spoke design/lip.
NEGATIVE
The hub mounting surface is toward the back or brake side of the wheel. “Deep dish” wheels are typically a negative offset and benefit the design process by allowing sharp angles, deep spokes and incredible layering.
Reactions: A5literMan
dz01
285
10
Massachusetts
Apr 15, 2017
  • Apr 15, 2017
Thanks!
General karthief
Mod Dude
Aug 25, 2016
28,133
10,750
213
polk county florida
Apr 15, 2017
  • Apr 15, 2017
Don't thank me, thank google.
But you are welcome, like boobs, I'm not totally useless.
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
Rear Disc and Rims Offsets
  • TripleYellow
  • Nov 11, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 9, 2026
TripleYellow
305-45-17 tires on Pony wheels (17")?
  • TTSaleen
  • Mar 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 25, 2026
TTSaleen
Fox Rear Seat Belts - 87-89 vs 90-93 length
  • dan50
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
Mustang5L5
