  • 1994 - 1995 Specific Tech
Oh Crap~!!!!!!!!!
  • Thread starter Thread starter Guero
  • Start date Start date May 8, 2006
  • 3
1 of 3 Next Last
Guero
2,148
May 8, 2006
  • May 8, 2006
Ok well i changed my oil, to see if did the noise and it stoped, well i took it for a ride, punched it and it just turned of. wont start just cranks
1TallMF
955
Montreal
May 8, 2006
  • May 8, 2006
crap... better read the codes and see what comes up and let us know
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
May 8, 2006
  • May 8, 2006
That sucks man. Hope you get everything figured out.
Guero
2,148
May 8, 2006
  • May 8, 2006
no codes
Zero Signal
2,633
Tucson, AZ
May 8, 2006
  • May 8, 2006
At least it cranks. It's probably electronic. I think a good Guero question would be . . . do you have gas in the tank
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
May 8, 2006
  • May 8, 2006
Is it getting fuel? Spark?
I remember you just installing a fuel pump. Does it prime when you turn the key to "ON"?
Guero
2,148
May 8, 2006
  • May 8, 2006
ok, i took of mine of my wires of the plug, put a screwdriver in it, and touched a negative while cranking. and no spark was is sparking, so im thinkging im not sparking. why is that?
Guero
2,148
May 8, 2006
  • May 8, 2006
the fuel pump turns on. but i get no spark
Guero
2,148
May 8, 2006
  • May 8, 2006
let me check!!! you basterd!!!!!
1TallMF
955
Montreal
May 8, 2006
#10
  • May 8, 2006
  • #10
Might have blown the TFI module or the stator in the distributor. Start by checking if there is 12V at the coil primary and work your way back. Gotta hate these kinds of problems...
Guero
2,148
May 8, 2006
#11
  • May 8, 2006
  • #11
the coil wire goes up to 12 volts when its connected to the coil
Guero
2,148
May 8, 2006
#12
  • May 8, 2006
  • #12
whats the tfi module??
Guero
2,148
May 8, 2006
#13
  • May 8, 2006
  • #13
if it cranks my heads and pistons are fine right????????
Guero
2,148
May 8, 2006
#14
  • May 8, 2006
  • #14
any one im panaking!!!!!
SeventyMach1
Mar 30, 2005
1,940
North Carolina
May 8, 2006
#15
  • May 8, 2006
  • #15
1st off .... take a deep breath & calm down, lol. Just be patient and you'll eventually find the culprit. The TFI (thick film ignition) module is what controls your spark output by sending information to your computer. It is very important.
Anyway, there are literally hundreds of things that could be wrong here. Again, don't panic. There are ways to diagnose this. I'll go ahead and post a quote from "jrichker" that may help you out. First, you NEED to determine for SURE if you are getting spark and fuel or not. You do not have to use the exact methods that he did ... but to keep me from typing all night .... this will get you started.
jrichker said:
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.)Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/article...c-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
Guero
2,148
May 9, 2006
#16
  • May 9, 2006
  • #16
the way i check for sparked i got no spark. so i would i determine which ones which?
B.)Coil
C.) TFI module
H.) Computer
HISSIN50
34
129
May 9, 2006
#17
  • May 9, 2006
  • #17
John, I hate to say that this was my first thought too. (no offense Guero - you crack us up).
The coil gets 12 volts constantly. The ground to it is pulsed via the TFI.
You really need to reliably check for spark. It would suck to think you dont have spark when you simply had too large of an air gap in your testing-method. An old spark plug, set on the upper plenum (so the threads are grounded) works well.
If you have a noid light, look for injector pulsing.
There are so many things it could be - any more info you can post will help.
Good luck.
Guero
2,148
May 9, 2006
#18
  • May 9, 2006
  • #18
i really dont know what to say. so the engine is good just the electrical?
Guero
2,148
May 9, 2006
#19
  • May 9, 2006
  • #19
its all good, i just can never write what im thinking and it comes out all messed up. like if im dumb lol
SeventyMach1
Mar 30, 2005
1,940
North Carolina
May 9, 2006
#20
  • May 9, 2006
  • #20
I agree that you should test REALLY WELL whether or not you have spark. (Not saying you didn't .... but I'm still not quite sure on the method you used)
(Adding to what JT said)
Use an old spark plug. Get a friend to do the cranking for you. Pull a plug wire and put the spare plug in it. Touch it to a ground (such as the upper intake plenum). Signal to your friend to crank. Be sure you have the plug GROUNDED when your friend cranks and that your holding the wire a little ways up, or else you may feel a nice jolt, lol (I wear a thick leather glove just in case). When (or if) you see spark, replace wire and move on to the next one. Check all eight. Let us know if you have spark.
BTW, make sure he puts the car in neutral, lol.
  • 3
1 of 3 Next Last
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
J
Foxbody trans swap
  • jimendo20
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
KRUISR
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
