I know its virtually as far away from mustang relations as you can get but im sure alot of the peeps on the forumn are interested and due stuff like this...
I wanted a trailer for my quad so I looked around at some used ones for sale and they were 2 things-JUNK!!!!! and overly priced, I then looked at some for sale at places like home depot etc. and they had the same problem so I decided to build my own,
I pretty much drew up the plans myself, i just looked around at a few trailers and grabbed the ideas i liked and put it all together the way i wanted it....
Its nothing special just a 7x9 tilt flat deck trailer, Currently the only thing i needed a trailer for was to haul my quad around with so I built this trailer with the tilt deck for easy loading,But if I need i can fit 2 full size quads on there if i load them sideways, according to local d.o.t. laws i was allowed to go 8 foot 6 inches wide and if i did that id have been able to haul 2 quads side by side but then the trailer is wider then the truck by about 10 inches a side and i wanted to avoid that....
I used a 3500 pound gvw rated axel (way way over kill for this trailer
but thats ok) I got it as a complete unit with springs and shakels minus rims and tires.....
the lights are common you can buy them anywhere, I sprung for the cool L.E.D. lights, I also put on a set of 5 inch backup lights just for the hell of it
i used a 3/4 inch plywood deck with a gallon of $9 stain slopped on it.... I went with a 2 inch ball
The bolt pattern is 4.5 inch center 5 bolt
so i grabbed a nice set of junkyard dog rims with good winter
tires for $40
I probly built the trailer way over kill for its initial purpose using a 3x3x1/4 toung, 2.5 x 2.5 x 1/8 main frame tubes, 2x2x1/10 cross members, 3x3x1/8 angle to cap the plywood with and the 6 inch channel bumper....... but hey if your gonna do it do it right...
it cost me probly alot more then you think it would but it was still cheaper then buying a trailer....
axel $180
tires/rims $40
steel $500
plywood $75
lights, hitch misc $200+
Then I wont mention the $1000 welder i bought and the 12.5 amp makita 5 inch angle grinder and the cool machinst square set... and on and on
but anyways if anyone has any questions or needs some suggestions on how to build one i can snap some pics for ya....... :canflag:
-gbm-
but thats ok) I got it as a complete unit with springs and shakels minus rims and tires.....the lights are common you can buy them anywhere, I sprung for the cool L.E.D. lights, I also put on a set of 5 inch backup lights just for the hell of it
....i used a 3/4 inch plywood deck with a gallon of $9 stain slopped on it.... I went with a 2 inch ball
tires for $40I probly built the trailer way over kill for its initial purpose using a 3x3x1/4 toung, 2.5 x 2.5 x 1/8 main frame tubes, 2x2x1/10 cross members, 3x3x1/8 angle to cap the plywood with and the 6 inch channel bumper....... but hey if your gonna do it do it right...
axel $180
tires/rims $40
steel $500
plywood $75
-gbm-
No spontaneous combusting or explosions? Man, you are slipping.
