  • SN95 4.6L Mustang Tech
oil capacity
  • Thread starter Thread starter lmpbzkt492
  • Start date Start date Nov 12, 2008
1 of 2 Next Last
L
lmpbzkt492
68
  • Nov 12, 2008
what is the correct oil capacity for a 2001 mustang bullitt? i put five quarts in and the dipstick read full but i have been reading around on the internet that some people say 5.5,6,6.5 so im kinda confused. also what kind of oil do you guys recommend. i put castrol syntec 5w-20 full synthetic in it. what do you guys run? i have read some people say 5-20 is too thin
P
poindexternasty
148
  • Nov 12, 2008
Is your motor stock or near stock? Stick with OEM spec. 5w20 is fine. 5w30 is fine too. I've run both in my 02 GT vert (stock) with no problems for 100k miles. I've also been using synthetic for the whole life of the car, as well. Mobil 1 or Royal Purple, whatever is available.
L
lmpbzkt492
68
  • Nov 12, 2008
how many quarts of oil are you guys putting in at oil change?
bhuff30
6,037
35
129
Olathe KS
Nov 12, 2008
  • Nov 12, 2008
6 Quarts will bring it to about the top of the full line. 5 Quarts isn't quite enough.
Everyone gets overly emotional about what brand and weight of oil you should run. 5W-20 or 5W-30 are both good weight choices and brand doesn't really matter, long as you change the oil regularly.
Having said that, I usually run mobil 1 5W-20 in the winter and 5W-30 in the summer. The car has 155k miles and doesn't smoke, so it seems to work just fine. You'll find a similar story for nearly every oil manufacture in existance.
My bottom line: lt's a Ford, even if you neglect the oil changes, the engine will still outlast the transmission!
P
poindexternasty
148
  • Nov 12, 2008
I've been using 5 qts the whole life of the car, 02 GT vert.
L
lmpbzkt492
68
  • Nov 12, 2008
thats what i figured. 5 quarts brings it to the full line on the dipstick
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Nov 12, 2008
  • Nov 12, 2008
I've always used 5.5 quarts in mine, 5w-30. Ford techs say 6 quarts so i would say anywhere between there is cool
H What 4.6
56
  • Nov 12, 2008
i use 6 quarts as stated in owners manual.... looks exactly correct on my dipstick
N
n0v8or
604
Rhode Island
Nov 12, 2008
  • Nov 12, 2008
This question comes up 2-3 times a year. The general consensus is Ford changed the engine oil capacity from 5 to approximately 6 quarts sometime during the 2001 model year. I suppose the '02-up pan is a different shape, but don't know this for sure.
In 2003, Ford issued a TSB pertaining to the 4.6L engine dipstick that was introduced in 2002. If you fill to the top hole, you are overfilling the engine (not good, because the rotating crank can whip the oil into a froth, and oil froth is not a lubricant). The approximate center of the crosshatched area is the maximum oil level.
It's no wonder customer confidence in Ford cars has been diminishing when they can't even design a dipstick.
xseler8
619
Montgomery County,Pa.
Nov 12, 2008
#10
  • Nov 12, 2008
  • #10
Put 6qts Mobil 1 5W-20 in yesterday.
theseeker411
14
Chattanooga, TN
Nov 13, 2008
#11
  • Nov 13, 2008
  • #11
At least Ford still has the brains to put dipsticks in their cars. New BMWs don't even have a damn dipstick. .
P
poindexternasty
148
#12
  • Nov 13, 2008
  • #12
This is because BMWs don't use oil for lubrication, they use the sweat of Chuck Norris. It never needs changing and is guaranteed to stand up to 2000 degrees while firing automatic weapons that never need to be reloaded, all the while defending freedom.
02nightmaregt
Jul 1, 2007
513
Southern Indiana
Nov 13, 2008
#13
  • Nov 13, 2008
  • #13
I usually dont fill to the top hole anyway so thats a good thing
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Nov 13, 2008
#14
  • Nov 13, 2008
  • #14
6qts puts it right on full.........
F
ForPointSex
395
Mercer, NJ
Nov 13, 2008
#15
  • Nov 13, 2008
  • #15
Ford put a 5 quart dipstick in some mustangs instead of 6 quart (my car). Even though my dipstick shows full at 5, I pt in 6.
flstang65
1,484
135
94
SE Georgia
Nov 14, 2008
#16
  • Nov 14, 2008
  • #16
i do 5 qts of mobil 1 and a can of engine restore.
T
ThunderHorse
26
#17
  • Nov 14, 2008
  • #17
I use 5.
twogts4us
4,188
12
79
Dunedin, FL
Nov 14, 2008
#18
  • Nov 14, 2008
  • #18
GREAT post!
FUNNY post!
J
JayC
674
Southern Indiana
Nov 15, 2008
#19
  • Nov 15, 2008
  • #19
Lots of bad info here. Read this quote from a former Ford design engineer. I run 7 quarts and will continue to do so.
"When at Ford, we ran with clear pans, windowed front covers and cam covers. The oil under high rpms gets slowed in the heads, the front cover and the front of the oil pan.
Front cover?? Oil pan??
As the chain drives the cam system, the oil is trying to get down thru the cover area. Also the area around the front of the pan shares space with the oil pump and pickup tube. Oil is trying to get back to the pan and everything is in the way.
The drain back holes are the same between 2v, 3v and 4v.
Ford conducts a WOT test for 100's of hours.
On the street you don't see consistent 6,500+ runs. On the track, I suggest you add 1 qt. Adding 1 qt does not over fill the pan to the point that the crank or rods run thru it. When at idle, you're 2 qts low anyways."
N
n0v8or
604
Rhode Island
Nov 16, 2008
#20
  • Nov 16, 2008
  • #20
Unfortunately, I can't take credit for the bad info; it comes directly from Ford.
The following paragraphs are copied directly from Ford TSB 03-8-3, titled "Engine Oil Level Indicator Markings". I am guilty of substituting the phrase "whipped into a froth" for what Ford calls "aeration (foaming").
"Ensure the vehicle is sitting on level ground. Set the park brake and ensure the transmission selector is in PARK position, or in FIRST gear on manuals. The engine must be OFF. The best time for determining oil level is before the engine is started and the oil has had sufficient drainback time to the sump. If the engine has been running, allow it to sit for a few minutes turned off. An oil drainback period is required before taking an initial reading.
If the level falls below the lower hole, fill with one quart of oil. If one quart is insufficient to raise the level above the mark, add oil until it records within the crosshatch area. Use caution during this procedure as some time is needed for oil to drain down through the drainback passages in the cylinder head, to the oil pan. Adding oil a quart at a time repeatedly without sufficient drainback may overfill the sump.
If the oil level falls between the upper and lower hole do not add more oil. Adding an extra quart could cause overfilling and may result in aeration (foaming) causing eventual damage to vital bearing surfaces and moving parts inside. Overfilling will require some oil to be drained out until the indicator shows the level between the upper and lower holes of the blade. DO NOT expect the engine to “consume” the extra oil back down to the upper oil fill level hole, or consider it as extra lubrication protection for the engine."
Perhaps oil aeration is more of a concern at moderate RPMs. It makes sense that the amount of oil remaining in the sump would be lowest at WOT, because it can't drain back fast enough.
1 of 2 Next Last
A
Engine 302 oil leak when in gear but fine at idle
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Monday at 3:42 PM
DadLife0724
Fox 351 dipstick showing overfull?
  • 387lx
  • Feb 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 9, 2026
Drivetrain Decode this Tremec tag?
  • Scott_S
  • Jul 25, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
