Oil choice for after break in period.
  • Thread starter Thread starter Sask84gt
  • Start date Start date Feb 28, 2026
First Prev 2 of 2
C
ctandc
5 Year Member
Oct 28, 2017
83
73
28
Mar 4, 2026
#21
  • Mar 4, 2026
  • #21
AeroCoupe said:
The tolerances in the newer motors are super tight so they need oil that can get in there hence all the 5W 20 and 0W 20 stuff. An pretty much all the new cars are running semi-synthetic or full synthetic from the manufacturer. Small block Fords were not designed around synthetic oils so its not necessary to run it. You can for sure run it as a lot of folks do and if you pay attention my guess is you will get more miles out of it and the higher cost is then moot.
I think it all stems from when people ran it too quick on a new build and the rings never set and they used oil. That went all over the internet and the "don't run synthetic oil" BS was born.
I do not run it because my engine builder told me to run the Brad Penn and with all the $$$ I have spent on these motors that is what they run.
FWIW the reason that so many new engines call for 5w 20 / 0w 20 has much more to do with EPA / CAFE mpg standards than engine tolerances. In the past 10 years or so there are multiple examples of the SAME engine going to a thinner oil with no other changes happening in that engine line. CAFE standards are calculated across the entire vehicle line. The tiniest 'gain' in efficiency for mpg can help raise the numbers for the manufacturer based on volume of vehicles.
One way you can see this easily - an engine used in both the U.S. and Europe, the SAME engine, will spec different oils from the manufacturer.
Reactions: General karthief and limp
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,516
2,936
173
Florida
Mar 4, 2026
#22
  • Mar 4, 2026
  • #22
The sad part is we now have some very expensive undependable, Hard to repair vehicles in the chase for unatainable MPG goals
nickyb
I gotta say i never painted my nuts, Never Ever
3,032
1,661
163
nevada
Mar 4, 2026
#23
  • Mar 4, 2026
  • #23
Exactly why the start/stop was put in newer vehicles.
My brother's 2022 vette Has that annoying and to shut it off he had to pay GM for the software to delete it.
limp
5 Year Member
Oct 4, 2020
5,516
2,936
173
Florida
Mar 4, 2026
#24
  • Mar 4, 2026
  • #24
Fortunately, my 2020 truck has a button to shut it off, but you have to press it each time you start it....
C
ctandc
5 Year Member
Oct 28, 2017
83
73
28
Mar 5, 2026
#25
  • Mar 5, 2026
  • #25
Every vehicle has a work around. Jeeps for example? There are TWO switches / sensor that determine if the hood is open. Unplug the right one? No check engine light - but stop / start doesn't work.
limp
5 Year Member
Oct 4, 2020
5,516
2,936
173
Florida
Mar 6, 2026
#26
  • Mar 6, 2026
  • #26
I should add that if I forget to press it and my Diesel engine shuts down at the turn signal some " Gosh darns" are commented upon...
P
Praetorious
102
55
38
living room.
Mar 14, 2026
#27
  • Mar 14, 2026
  • #27
I hate that function so much but not for the reasons most would think,i hate it with a passion cause it drives me crazy listening to it, ha ha ha, like when your traveling for 8 miles next to someone and you gotta hear that at every stop light, its like "man, rip that thing out!!! ha ha ha, all my cars i drive are old so i have never experienced that annoying thing myself.
On the subject of the oil i use Driven 10W 30, been using it from day one on my 347 build, i figure if i spent that much money on a motor, 70 bucks every few months is not a bad investment, that oil is green, pretty weird looking, since i built that engine 3 years ago i have logged every single oil change, how many miles etc , i used Comp break in oil for the first 500 miles or so, good stuff.
First Prev 2 of 2
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
T
Turning over fresh 347 stroker torque question
  • TexxDex
  • Apr 1, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 1, 2024
Bullitt347
J
  • JRC99
  • Apr 19, 2025
JRC99
J
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
