Oil drain gaskets - best material
Mustang5L5
Mod Dude
Feb 18, 2001
43,369
18,116
224
Massachusetts
WHat gasket material do you guys use for your oil pan drain plugs??
Hard to beleive, but I still have the original gaskets as far as I know on my drain plugs. I need to replace them. The originals are plastic.
Right now i have the blue neoprene stye gaskets, copper gaskets and a couple of new plugs plugs that have molded on rubber on the ends. Unsure which to go with.
What do you guys use that reliably does not leak? :shrug:
dead soft copper or the molded blue rubber would be what i used. ive used them in the past with out issue. the volvo uses a aluminum or steel not sure which (the company i order from ships the with the filter) and they have to be replaced every oil change which i think SUCKS
