Oil Filter Construction
  • Thread starter Thread starter 90mustangGT
  • Start date Start date Jan 16, 2010
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jan 16, 2010
  • Jan 16, 2010
I saw some vids online where some guys are taking apart some oil filters.
It's amazing what kind of POS a Fram filter is.
YouTube - What's in a Fram extra guard filter?
and this one shows filters for our cars.
YouTube - Fleetguard the best
That fleetgaurd looks good doesn't it?
Mobil 1 is a ripoff, I don't see what is so special about it?
YouTube - What's in a mobil 1 filter?
Wix looks pretty good, I would trust that:
YouTube - What's in a Wix filter?
Amsoil is a machine in itself:
YouTube - What's in an amsoil filter?
I have used the Motorcraft filters for my Fords and AC Delco for my Chevy. I took apart the AC Delco the other day and it looks pretty good, probally right up there with the wix. Haven't done it to the Ford filter yet but I will. I might have to order some fleetgaurds.
So what do you use in your car?
MustangLX-5.0
856
Lehigh Acres Fla.
Jan 16, 2010
  • Jan 16, 2010
Yeah, I always known Fram was junk. Pieces of the filter can break off and either get in the system or clog the oil passage. I have never once bought a Fram. I have always used either Purolator Pure One, Motorcraft, or K&N. They all hold up well. Never a problem .
Mustang5L5
Mod Dude
Feb 18, 2001
43,332
18,059
224
Massachusetts
Jan 16, 2010
  • Jan 16, 2010
I use Purolator Pure one...which is what the Motorcraft filter is (Pure One cartridge in a classic case)
HotFox
1,068
701
164
SE Michigan
Jan 16, 2010
  • Jan 16, 2010
I use Wix, have been forever, good old Auto Value parts store. Although in the mustang I use Jomar non-bypass oil filter.
Scott
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Jan 16, 2010
  • Jan 16, 2010
the Purolator pure one is supposed to be a real good filter, I use it on my daily driver, I use motorcraft on the mustang religiously.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Jan 16, 2010
  • Jan 16, 2010
This guy recommends the KundN.
watch it till the end, it's worth it.
YouTube - K&N Oil Filter
90mustangGT
2,773
17
89
Dallas, GA
Jan 16, 2010
  • Jan 16, 2010
OMFG.... he sure was excited about that oil filter. All that money on the expensive oil filter that he paid $19.95 and I bet they used the pump "mystery" grade dino oil.
9
94gtfreak
412
your moms house
Jan 16, 2010
  • Jan 16, 2010
I used to work at a factory that made all the rubber seals and anti-drain back's for all those filters. I've always used Fram filters on everything.
Finally bought my first Motorcraft filter the other day and can't wait to see if it's any better.
90mustangGT
2,773
17
89
Dallas, GA
Jan 17, 2010
  • Jan 17, 2010
I really don't know how you could "tell" unless you had your oil analyzed.
I know this much, the filters with that have a good anti-drainback feature will really help during cold starts. The one's with lots of pleats have more filter material and will have higher capacity. Those with metal endcaps will keep the media stable and prevent it from shifting or oil from bypassing the filter. A bypass valve isn't as important but would prevent oil pressure loss if the filter did become clogged.
What has suprised me at my work is those who spend lots of money for expensive synthetic oils and yet never think twice about the filter we are using.
281pony
2,681
Oly, WA
Jan 17, 2010
#10
  • Jan 17, 2010
  • #10
cant wait to send that video to my girlfriends "never been wrong" stepdad. i was just telling him today how i hate fram filters for that reason. he is a mechanic and a loyal ford guy btw. he told me motorcraft and fram are the same inside.
aar0s
1,015
55
69
Jan 17, 2010
#11
  • Jan 17, 2010
  • #11
Ive been using the fl1a in my mustang for years, used a Baldwin before that and both seemed to do alright. I used some kind of cheep ass filter (maybe a fram) once and didn't get as good a oil pressure with it. I looked on youtube and didn't find anything but i would like to see what the Baldwin has in it.
Mustang5L5
Mod Dude
Feb 18, 2001
43,332
18,059
224
Massachusetts
Jan 17, 2010
#12
  • Jan 17, 2010
  • #12
When i had my Mark 8, they were notorious for the cam chain tensioners to rattle on startup. I ran fram filters back then and my Mark 8 would sound like a homeless man begging for change with all the rattle.
I read up on how much Frams sucked and switched to motorcraft....and the startup rattle went away!
90mustangGT
2,773
17
89
Dallas, GA
Jan 17, 2010
#13
  • Jan 17, 2010
  • #13
As long as I have been working on cars there is so much I didn't know about the oiling system. I knew about the bypass inside the oil pump to regulate the pressure, I didn't know about the one that is in the oil filter itself so basically not all of the oil is getting filtered.
HotFox
1,068
701
164
SE Michigan
Jan 17, 2010
#14
  • Jan 17, 2010
  • #14
Yes that is right it is there more for on cold starts, the oil pump can not force the cold oil thru the filter so the bypass opens up or if the filter gets plugged then the bypass would open. That is why I use a Jomar non bypass filter on my car which is parked during the winter anyway.
Scott
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
C
Knocking after pull- went away?
  • Connormcclark
  • Oct 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 6, 2025
gkomo
Engine 8.2 oil filters whos still making decent ones?
  • rednotch
  • Oct 24, 2024
Fox 5.0 Mustang Tech Oct 26, 2024
rednotch
D
Engine Is this an aftermarket oil filter adapter?
  • dqureshi06
  • Jun 1, 2024
Fox 5.0 Mustang Tech Jun 1, 2024
General karthief
O
8.8 Pinion Nut Leak
  • OX1
  • Jan 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 5, 2026
OX1
O
