  • SN95 4.6L Mustang Tech
oil filter relo
  • Thread starter Thread starter timeless2
  • Start date Start date Aug 2, 2005
1 of 2 Next Last
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Aug 2, 2005
  • Aug 2, 2005
Searched and didn't find anything directly on relocation....
I saw a kit on Jeg's site and wanted to do this, just for quick changes without spillage. Is it worth it? Has anyone done it?
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=10431&prmenbr=361
Should a cooler be a priority over this? I want my car to go the distance as far as mileage goes and to have ultra quick oil changes in the meantime.
T
TripleBlk
312
Cape Canaveral FL
Aug 2, 2005
  • Aug 2, 2005
Supposedly, the 4.6 engines have a patented oil cooling system built-in. Don't have or haven't seen any details on this, yet.
I'd be interested in a relo kit, but the ones I saw in Jeg's (your link) and Summit all specify the Fram filters. I wonder if they use NPT fittings or not ?
timeless2
Admin Dude
202
154
the Shadow Gallery
Aug 2, 2005
  • Aug 2, 2005
There is an integrated oil cooling system? I would like to hear more on this.
I'm seriously looking at the oil filter relo. If I do it, I'll surely do a write-up. I hate spilling the dumb filter. Even covering it with a plastic bag makes a mess. Yes, the relo kit uses a Fram ph8a or equivalent.
forpit2000gt
2,490
Columbia, SC
Aug 2, 2005
  • Aug 2, 2005
probably start a debate here but don't use Fram filters. Also, if you drain the oil completely, I haven't had a problem with a mess.
timeless2
Admin Dude
202
154
the Shadow Gallery
Aug 2, 2005
  • Aug 2, 2005
No, I wouldn't use Frams........just showing the universal applicability of the relo kit (the JEG's site is).
DageonYar
48
  • Aug 2, 2005
Sorry to pipe in here... but why not use Fram? Just curious cuz I just did an oil change and slapped a Fram on.
timeless2
Admin Dude
202
154
the Shadow Gallery
Aug 2, 2005
  • Aug 2, 2005
Some people feel they don't have the protection.
Personally, I've seen my dad use them for years and have most of his trucks go well over 200K miles, so go figure?
T
TripleBlk
312
Cape Canaveral FL
Aug 2, 2005
  • Aug 2, 2005
http://www.freepatentsonline.com/5406910.html
Just found the patent on the oil cooler.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 2, 2005
  • Aug 2, 2005
Only Cobras have oil coolers. They use circulating engine coolant to lower the oil temp and have a feed and return line to the coolant system.
In the FRPP catalog the oil relocation kit has a note that states "not for racing applications". I believe that this is due to the fact that extra turns, bends, and distance in the path to and from the oil filter cause a reduction in pressure/flow.
I personally do not recommend oil filter relocation.
I use a large sheet of aluminum foil below the filter to channel the used oil into my drip pan which prevents it from getting all over the steering gear and driver's side A-arm. I cleaned all the old oil residue off these parts with carb cleaner and they look shiny and new always now
Also, Motorcraft oil filters have an anti-reverse valve in them that prevents oil from draining back into the pan and causing a cold start rattle. I believe it is best to ALWAYS use Motorcraft parts for your expendable maintenance items...
T
TripleBlk
312
Cape Canaveral FL
Aug 2, 2005
#10
  • Aug 2, 2005
  • #10
Hmm. Yeah, that's why I said supposedly - didn't the 4.6 Police Interceptors have an oil cooler builtin, too ?
timeless2
Admin Dude
202
154
the Shadow Gallery
Aug 2, 2005
#11
  • Aug 2, 2005
  • #11
KT, good post.
I plan on using the MC oil filter. Did not know that the filter had a valve in it to prevent such spillage. Always used Frams or Napa golds on my past vehicles.
As for the foil, that is a good, cheap alternative, I suppose. The only problem there is that you count on there being no wind. I live in the Great Plains where if the wind is NOT blowing, something is bad-wrong. Makes it tough to hold foil in place, let alone the drip-stream of oil going everywhere under the car. Problem solved, if I can trade up in houses (maybe this week) for a two car garage (one car right now, only).
forpit2000gt
2,490
Columbia, SC
Aug 2, 2005
#12
  • Aug 2, 2005
  • #12
I don't want to start a war in here and maybe I should not have said, don't use Fram. Fram filters are inferior to for example, Motorcraft, there are other filters as well. If you change your oil regularly, they will be alright. There are just better filters on the market that are not very expensive.
do a search on fram filters and you will read all you care to.
Some different filters are made in the same place with different specs and materials.
sgarlic
3,085
Aug 2, 2005
#13
  • Aug 2, 2005
  • #13
Anyways, he asked about relocating the oil filter.. let's get back on topic. I for one would like to hear what comes of this.
timeless2
Admin Dude
202
154
the Shadow Gallery
Aug 2, 2005
#14
  • Aug 2, 2005
  • #14
I saw the initial relo done within this article on Mod Depot.
http://forums.modulardepot.com/showthread.php?s=&threadid=58817
The idea goes a bit far for what I need, but would a relo and cooler really lower oil pressure on a stock setup like mine?
KronicRacer
502
puttering around Ft Lauderdale, FL
Aug 2, 2005
#15
  • Aug 2, 2005
  • #15
ive always been interested in a double filter setup.
MT1083
1,033
Charlotte, NC
Aug 2, 2005
#16
  • Aug 2, 2005
  • #16
MM has an oil filter relocation kit.
timeless2
Admin Dude
202
154
the Shadow Gallery
Aug 2, 2005
#17
  • Aug 2, 2005
  • #17
Sorry, but what/who is "MM"?
MT1083
1,033
Charlotte, NC
Aug 2, 2005
#18
  • Aug 2, 2005
  • #18
http://maximummotorsports.com/oilfiltreloc.asp
timeless2
Admin Dude
202
154
the Shadow Gallery
Aug 2, 2005
#19
  • Aug 2, 2005
  • #19
Nice but oh , the price!
M
Mustangl3
242
willow grove, pa
Aug 2, 2005
#20
  • Aug 2, 2005
  • #20
isnt the PH8A filter for a 5.0? I know ity doesnt matter but thought i recognized the number
1 of 2 Next Last
R
Fox Closed PCV System, Dual Valve Catch Can
  • RTW0223
  • Dec 6, 2019
15K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 30, 2021
jay98
Fox T5 To Aod Conversion
  • 86GTVert#2
  • Jun 29, 2016
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 30, 2016
86GTVert#2
Benifits of an Oil cooler?
  • trombonedemon
  • Mar 23, 2010
3K
1996 - 2004 SN95 Mustang -General/Talk- Oct 21, 2010
trombonedemon
Remote Oil Filter Relocation Kits
  • twogts4us
  • Aug 24, 2009
6K
SN95 4.6L Mustang Tech Aug 29, 2009
Pearl02
  • Locked
91mm Turbo Mustang Project Car
  • cv334
  • Jul 3, 2011
3K
SN95 Mustangs For Sale (1994-04) Oct 4, 2011
OneQuick01
O
