Oil for 347? 20w-50?
Joe 5.0
1,184
Macomb, MI (metro detroit)
Just bought a built cobra with a 347, and the previous owner always ran 20w-50 Amsoil. The only thing is that its $9/qt, and it goes through about a an extra qt every oil change, and it has a 7qt pan.
Do I HAVE to run this thick of an oil? Will it burn off something thinner, like a 10w-30 Mobil 1 that much more? Is the 20w-50 that much better at protecting the engine?
Did the PO mention having an oil control issue?
If you go thinner, it will be more likely to burn, generally speaking. I suspect that's why the thicker oil was used...........
I would be wanting to try what Mike uses. I'd try and track down where the oil is going.
Good luck.
