Oil Galley Plug Blew Out
duo_z
78
So finally after many questions and much research I had finished building my 289. I built a test stand, checked everything and hit the starter button. After a little trouble shooting and some tuning she would fire up with not even a half turn of the starter. She sounded sweet. During my enjoyment and happiness I noticed the oil pressure gauge not giving me a reading. So I shut it down and started troubleshooting everything from gauges, hook ups, and the engine it self. I found oil to coming out of the sensor extension, but not my push rods. So I pulled the dizzy and found the problem. An oil galley plug was laying on the lower dizzy support. So half sad and half pissed I started ripping her apart. So I'm wondering could it have been I didn't push it in deep enough, is there something I should look for that could have caused it otherwise?
Sounds like a good idea, I should have thought about that when I put them in in the first place. Hopefully I can do that this weekend and have it back up and running before next week. And if all goes well I will post some pictures and a video.
Thanks:nice:
i always thread and use thread in plugs ,you can do it your self .it isnt hard
to do ,just need a pipe tap and screw in allen head plugs,do it before you start your
build you dont want shavings in your oil galleys, wouldnt do it now unless you are
tearing it back down all the way, i would use lock tite on the press in plugs, new ones
not the old ones ,clean the holes out good and oil free first and then stake the plugs
as well. for the freeze plugs seal them as well i always use the deep brass plugs
you should never have a problem with them,if the short freeze plugs arnt drived in
strait they will leak
