Here's the comments from page 9-44 of the CRAI8 document:
When the airmeter fails due to contamination (oil/dust) on the element, it goes rich at low flows and lean at high flows. Since it is impossible to adapt at max AM, the correction learned at lower flows is applied. When the lean correction learned at low flows (due to rich condition) is applied at high flows, the already lean condition at max AM gets worse, causing engine overtemp. This logic prevents the application of such erroneous correction.
What then follows is some code that will fudge the numbers so that the leanness isn't nearly as bad as it could potentially be. The take home from this is to keep the meter clean, as it is the PCM's primary method of judging how much fuel to inject.
Wes
