Oil on dipstick always too high.
Red66GT
214
Simi Valley, CA
Everytime I change the oil (and filter) I've been putting 5 quarts in. When I do this the reading on the dipstick is always about a quart too high.
The cars got a 289 in it and I'm pretty certain the stock oil pan. Do all 289's take 5 quarts???
I also get oil seeping out of my valve covers, I've changed the gaskets w/ the rubber ones you can get at autozone but it didn't help.
Could this be related to having too much oil in the engine, (that its just forced out)?
The oil pressure guage reads normal, a little less than half way on the stock guage.
Can anyone chime in?
If the rubber valve cover gaskets just suck, can anyone recommend some good ones?
Not sure on the oil capacity,seems like 5 quarts should be correct.On the valve pan covers it sounds like they may have been overtightened.What you could do is pull them off and check them with a straight edge.If you see alot of high and low spots thats the problem.You could try to straighten them the best you can and reassemble.Should be fine.
stock oil capacity is four quarts in the pan and one in the filter. you should be checking the oil level AFTER you have run the engine, gotten oil pressure, and checked for leaks. if you have an extra quart after that, then you likely have the wrong dipstick.
as for the oil leaks from the valve covers, i agree you have a warped edge, or the bolt holes are dimpled.
my 302 takes only 4 when I use the short oil filter, 4.5 when I use the regular filter (motorcraft FL1A). Matching pan and dipstick. Pressure never drops when I slam on the brakes or launch at the strip, so it must have enough in it. 5 qts clearly shows overfull on my car.
