  • SN95 4.6L Mustang Tech
oil on plugs??
  • Thread starter Thread starter SaleenGT2001
  • Start date Start date Jul 14, 2007
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jul 14, 2007
  • Jul 14, 2007
my buddy has a 97 GT and it has been missing/skipping lately. i put the xcal on it and found that #4 was the misfire. so we pulled the plugs and they were all gapped at .060 and 7 were white on the tips. the #4 was covered in oil. the oil had fouled the plug out causing the misfire. i told him i thought the rings must be going. the car has 110K. is there anything else that can cause oil on the plugs?? what is the right gap for a stock car?and what causes the plugs tobe white??running lean?
40th GT
916
Lawrenceville, GA
Jul 14, 2007
  • Jul 14, 2007
.060 is too far. The recommended range is .052-.056. Most people stick with .054. I think your plugs were white because of the huge gap.
From a optimistic point of view, the #4 plug is oily because the COP isn't working. COP's are cheaper than piston ring swaps, so check the voltage on the COP.
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Jul 14, 2007
  • Jul 14, 2007
Yep, like 40th said, he's running lean because of the gap. Take it down to .54 and hope to God that it's th COP. A piston ring is going to be expensive as hell on labor, and a total PITA if you guys do it yourselves. Good luck, I hope it isn't too serious.
the98stang
2,408
Clovis, CA
Jul 15, 2007
  • Jul 15, 2007
Was the oil on the plug threads, or above the threads, near the top of the plug (where the COP connects)? If the oil was above the threads, then he probably has a leaky valve cover gasket. If the oil was on the threads, he may have worn rings. You can do a simple compression test to check the rings on the car. If a cylinder is reading lower than the other, drop a cap full of oil into the chamber, and see if the compression numbers go up. If they do, the rings are worn. If that's the case, I would just run straight 30 oil, and the engine might last quite longer than you think.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jul 15, 2007
  • Jul 15, 2007
it is 98 so it doesnt have COP. it hasthe 2 coil packs in the front. thanks for all the advice guys!
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jul 15, 2007
  • Jul 15, 2007
TweekedGT
1,274
Alberta
Jul 15, 2007
  • Jul 15, 2007
A 97 won't have COP's, just coil packs. The white is the car running lean, .060 is pretty big. Take a spin with him after and follow in your car. See if it's blowing any smoke, then you'll know for sure if the rings are gone.
the98stang
2,408
Clovis, CA
Jul 15, 2007
  • Jul 15, 2007
My bad, forgot we were talking about an older stang
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jul 15, 2007
  • Jul 15, 2007
no smoke from the exhaust.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jul 15, 2007
#10
  • Jul 15, 2007
  • #10
you could do a compression test if the new plug still misfires
could be a bad plug wire
  • Gulftown980x
  • Jul 29, 2026
squeak93
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
