Oil On upper Intake Gasket and Around Vacuum Hookups...What Did I Do?
Sounds like you're sucking up oil through your pcv valve. There was a thread a couple days ago started by killercanary about using a supercoupe pcv. You might want to check that out. Also might consider putting a breather cap on your oil fill neck, or an oil seperator.
Mine does that to....I thought it was my breather set-up to...so I reconnected it when I did my Cobra intake....No dice...same deal. Mine sucks quite abit up...I can teel as my phenolic spacer has turned all dark so I know its getting oil..
I just bought this set-up....Should be here this week...I curious as to how much oil is getting by...
My screen is clean, everything was replaced during the swap....Its just sucking it in.... :shrug:
Andy, are you using a dedicated A/O separator (a la Steeda) or a more generic separator? I still am not sold that a 15 dollar cheapo A/O separator will suffice. Thoughts (I need to do one on the 94 myself)?
Thats the Steeda unit i ordered...I read around on some other set-ups you could make, ala Campbell/Hausfield separator...the only issue was they stated it was a pain coming up with the threaded 90's...and I wanted to make sure I had the right filter media...
I don't feel like messing around hunting stuff up...I want it all in a kit....done deal... :D
It was 68.59 shipped from Steeda...
