what oil pan do i use for a 1995 5.0 in a 1965 mustang coupe with the serpentine system from the 5.0 and power steering that was already on the car
thanks guys, in advance
65inworks said:i was told that ford changed the block and that the bolt patterns from the two where the oil pan is supposed to bolt up is different i dont know if this is true. is it?
96 DOHC Cobra said:Not true. Any 260, 289, 302 pan will bolt onto the 95 5.0 motor. He will have to drill the timing cover for the dipstick tube OR swap over his existing timing cover then buy all aftermarket brackets and pulleys to be able to keep the serpentine setup.
