Oil Pan Gasket Change - Prime Oil Pump?
I'll be attempting this with the engine still in the car. All I'm doing is dropping the pan far enough to snake in a new gasket. In my searches on this board, I found a couple posts where jichker has copy and pasted his how-to, and he states its necessary to prime the oil pump after this job. I don't get it?! How is this any different than an oil change as far as the pump is concerned?
On a side note, my car went from dripping a drop of oil every night (which I didnt care about, and thought was the rear main), to leaving a 1 ft diameter puddle on my garage floor after changing the oil the day before. It hasn't been driven since October, but started 3 or 4 times to move it around the garage. I got under there and looked and the side of the gasket (pass side) is completely blown out! Amazing.
ive swapped pans and didnt re prime the pump. the only reason for repriming is when the pump is removed and ALL oil is gone from the motor. i guess it depends on how long you have the pan off. most oil changes dont last long and the oil probably never has a chance to completly drain out of the motor. well thats my theory on it anyways.
I have only heard of priming the pump after installing a new one. If you are just dropping the pan then it's really no more than just an oil change really. I have done pan gaskets on other motors and never primed the pump. make sure if you use a new filter to fill it with oil so you don't have a dry start. you could always bump the starter a few times before firing it to move some oil around but I'm sure you will be fine.
FYI - I was successful in swapping gaskets with the engine still in the car. Here's some tips that will hopefully help someone else:
1. Summit part number FEL-OS34508R is definetly the one to buy. It's a one-piece gasket, with a steel core, and it comes with 4 plastic guides that hold the gasket, pan, and reinforcement in place. Those clips are like having two extra pairs of hands under there.
2. As far as what to remove/unhook and what not to, I unbolted by H-pipe, tranny mount, motor mounts, intake tube, removed fan (but left radiator and shroud in place), and I had to pull my distributor cap because it was going to hit my strut tower brace.
3. I jacked the motor up enough to put small 2x4's between the motor mount halves.
4. I did not prime the oil pump, but did bump the starter a few times prior to starting. When I did start it, oil pressure jumped up just as fast (if not faster) than when I do an oil change.
5. I did not remove the oil pump or take the pan out from under the engine.
Hopefully that helps someone.
