Oil pan removal
Max Power
1,774
St Paul
Anybody ever replace an oil pan or pump in a 69 with a 351 windsor?
Did you drop the center section, or juct jack the motor way up?
If you dropped the center section, was it easy to bolt back up?
I am a little apprehensive about removing a structural support piece.
bnickel is right, no need to raise the motor, just drop the cross member, maybe un-do the joint at the idler arm and pass side tie-rod to give yourself more room if you have power steering. it should be fairly easy.
