So I am pretty sure no one knows why you posted the two pictures. If you are contemplating buying it I would say $250 (even Canadian) is way high. Also, that pan will not fit a 1989 5.0 Mustang. Fox body cars require a double sump pan as the oil pump in the front sump and the pickup tube is in the rear sump. Both sumps have drain plugs.
This is more what you want for an OEM replacement with a provision for the low oil level switch:
If you do not have or do not want the low oil switch then use a M20x1.5 oil pan bolt with gasket (most parts stores carry them) and plug the hole.
