  • SN95 4.6L Mustang Tech
Oil Pan Tap?
  • Thread starter Thread starter blacknblue2002
  • Start date Start date Mar 27, 2006
blacknblue2002
159
Va Beach, Va
Mar 27, 2006
  • Mar 27, 2006
I'm preparing for my supercharger install, and I bought a universal oil return fitting from www.dssracing.com....Has anybody else used one of these?...I want to know if they actually make the oil pan modification any easier and if there are any other recommendations for the return line. I'd appreciate any input.
M
mac1009
187
Atlanta, GA
Mar 27, 2006
  • Mar 27, 2006
Correct link is here:
http://www.dssracing.com/power_adder_fitting.html
From what I can tell, it looks like you need to cut a hole into the oil pan and then attach the backing plate to it. Is this correct? If so, you'd have to drop the pan, which would require you to drop the k-member as well. What's your hesitation w/ tapping the pan?
BennyBlown2v
1,233
Carmel, INdiana
Mar 27, 2006
  • Mar 27, 2006
You puting on a Vortech blower? Go to www.vortechsuperchargers.com and read the manual for the install - the oil pan tap instructions are very detailed and purty much all you need to know... However, I would advise instead of using silicone on the threads use JB weld, this will insure that the fitting ain't going no where. Also, it's hard to find a tap wrench that will fit a 3/8" Pipe tap, so if you can't find one just use a 11/16" (i think) socket and socket wrench T handle.
blacknblue2002
159
Va Beach, Va
Mar 27, 2006
  • Mar 27, 2006
I've been checking out the vortech site...Thanks for the input
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
T
Service Fluid Recommendations for 2015 Paxton Supercharged GT
  • ThotTrap
  • Aug 25, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 25, 2025
ThotTrap
T
  • Gulftown980x
  • Jul 29, 2026
squeak93
Engine Oil Pan Question?
  • daredevil95
  • Apr 29, 2024
Fox 5.0 Mustang Tech Apr 30, 2024
AeroCoupe
J
Hello all, I have returned from a hiatus... Update and Questions
  • JackH
  • Aug 13, 2025
1974 - 1978 Mustang II Talk & Tech Aug 15, 2025
JackH
J
