I am having some oil pressure problems on a motor I just put in my car. It was a used bottom end but the oil pressure was great and the only thing I did was add a windage tray to it. I am guessing that maybe when I installed the oilpickup tube back on it that I messed up some clearances or something.
when I first start up the motor the oil pressure is really high. Once the car warms up the pressure on the guage drops alot and then you can hear the valves start to chatter. If you rev the motor the oil pressure rises and then falls back to where it was. What could the problem be?
