Moosee1955
- Sep 30, 2016
- 267
- 55
- 38
You didn't say you had this problem before. You probably have a cracked block if it did this with old heads. If it was me I would have stripped the motor down to bare block, and have it magna fluxed for cracks, before plunking down for new heads. I hope I'm wrong, but if you had the same issue, you more than likely have a crack in one of the cylinder bores. Keep us posted what you find. Take your block to a good machine shop, unless the crack is real obvious. You'd definitely lose oil pressure and power if cylinders won't seal, and hold compression/ oil pressure.
Sent from my iPhone using Tapatalk
. But I am gonna go check the passenger side head gasket now. I'll check the driver side either tomorrow or this weekend. Depends when I wanna pull a pulley off lmao.
how are you going to do anything to an engine and not change the
ing oil?
how are you checking the head gaskets?
