Like it says, I replaced my braided lines running to my oil pressure lines tonight. I have a 8.5" long 4AN line running to a 1/4" tee-fitting, where the factory oil pressure unit sits on one side. On the other side, another 12" 4AN braided line runs to the AM unit, sitting next to my fuse box. I had to lengthen the factory wire for the unit by about 3 inches. They work fine at idle, and at cruising, but under acceleration or revving, they both go dead. WTF?! I have no idea why this is happening. It can't be electrical, because they are wired seperate. It can't be a blockage in the lines, because then they wouldn't work at all. My friend said tonight it sounded like I had a vacuum leak because of the way the car was idling (it was idling a little rough after initial startup, but I had the battery disconnected for about 2 hours). Would a vacuum leak cause oil pressure loss under throttle? I am stumped, these damned oil pressure gauges are pissing me off. Any help is appreciated, thanks.
. The other end just goes to a ground you like.
