Oil Pressure
  • Thread starter Thread starter stang_702
  • Start date Start date Apr 15, 2007
stang_702
Birmingham Alabama
Apr 15, 2007
  • Apr 15, 2007
Anyone know what could cause the oil pressure to drop when accelerating. At idle oil pressure is fine, at part trottle oil pressure fluctuates from 50 to 20 psi. This doesnt occur all the time so I know it couldnt be mechanical. Sending unit is new and installed new rod, main bearings about 8000 miles ago. Oil pump is new as well, could it be electrical?
89 Mustang GT, AFT 185 heads, F303 camshaft, mac headers w/exhaust, 24lb injectors
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Apr 16, 2007
  • Apr 16, 2007
When the car heats up it will drop. From 50 at start up to 20 hot is what mine does. But, it should jump from 20 to 30 or so when accelerating. The oil heats up and thins out a little.
ninety15.0
1,336
  • Apr 16, 2007
Are you using the stock gauge? If so, dont do anything until you get a reliable mech. gauge on there and see whats really happening. I also thought i had serious OP problems and i changed out the sending unit to no avail. I hooked up a nice autometer mech OP gauge to find out that everything was fine.
Kdubslugga
1,515
Akron, OH
Apr 16, 2007
  • Apr 16, 2007
yes my stock guage was reading next to nothing at hot idle, i got an auto meter which read 20 psi at hot idle
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Apr 16, 2007
  • Apr 16, 2007
mine has been reading ZERO ever since I got my car lol engine does knock but stock gauge sucks anyway... Get yourself a good mechanical gauge before thinking it's the engine, man!
stang_702
Birmingham Alabama
Apr 16, 2007
  • Apr 16, 2007
thanx, I will try a mechanical and see what happens
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Electrical Oil Pressure Gauge IN Dash Cluster Unresponsive
  • Nine Finger Wrenching
  • Jan 7, 2025
Fox 5.0 Mustang Tech Jan 8, 2025
85GTStangGuy
C
Engine Oil pressure issue
  • Cg’s 347
  • Jan 15, 2024
4K
Fox 5.0 Mustang Tech Mar 2, 2024
AeroCoupe
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
