Oil pressure?
  • Thread starter Thread starter TrickFlowd
  • Start date Start date Oct 1, 2007
TrickFlowd
240
Sayre, PA
Oct 1, 2007
  • Oct 1, 2007
Whats good oil pressure on stock bottom with trick flow top end? mine is around 50 lbs at idle and seems to drop some at WOT. Could this be caused from thin oil? I'm running Purple Power full synthetic with Fram filter. I would like to change to Mobil 1 synthetic since purple power is so expensive and harder to find than Mobil. What u guys think?
N
N02-87FOX
  • Oct 1, 2007
I use nothing but royal purple you can pick it up at any napa parts store. Mobil 1 changed there synthetic to semi-synthetic and still label it as synthetic.
TrickFlowd
240
Sayre, PA
Oct 1, 2007
  • Oct 1, 2007
how often do you change your oil? I just bought the car so I'm not sure.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Oct 1, 2007
  • Oct 1, 2007
oil pressure should NOT be dropping under throttle...I'd be curious to find the cause of that for sure.
F
Fox8950
247
Oct 1, 2007
  • Oct 1, 2007
Same here pressure should only raise slightly with more rpm, that is odd to have it drop. Are you using stock gauge? I use nothing but the mobil 1 extended performance (15,000 mile stuff) and have nothing but good things to say ... in fact it majorly saved my bearings on my old stang even after it was drivin a few miles after the oil pump shaft turned into a twizzler.
TrickFlowd
240
Sayre, PA
Oct 1, 2007
  • Oct 1, 2007
autometer gauge. I just bought the car last night...for a steal price. It has somewhat of a leak on the timing chain cover...could this help with the drop in pressure?
F
Fox8950
247
Oct 1, 2007
  • Oct 1, 2007
Little leak shouldn't really effect your pressure much and at least your not relying on the good ole craptastic factory gauges afraid I think I'm just about as stumped as you atm. I'd go investigate how the previous owner hooked up his gauge and stuff and if the gauge all looks good keep a close eye on oil level/pressure for a while and see what happens if you don't feel like digging in quite yet.
TrickFlowd
240
Sayre, PA
Oct 1, 2007
  • Oct 1, 2007
false alarm! I found a small crack in the gauge line. fixed that, and shes back to normal. about 51psi at WOT and stays around 30 at idle. I think thats pretty much perfect?
bentley429
Banned
Nov 25, 2004
528
Connecticut
Oct 1, 2007
  • Oct 1, 2007
Sounds good to me! Rule of thumb is 10 psi for every 1k rpm, though I wouldnt want my car idling at 10 psi....
TrickFlowd
240
Sayre, PA
Oct 1, 2007
#10
  • Oct 1, 2007
  • #10
Thanks! Hopefully things stay that way.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Oct 1, 2007
#11
  • Oct 1, 2007
  • #11
It could if you had a high volume pump and didn't have a 7 quart pan on the car. You can pump a sump dry at WOT thus loosing all oil pressure. Atually even with my 7 quart pan I do notice a drop in my oil pressure while at the track and on the bottle.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
SBF rebuild with no oil pressure NEED HELP
  • Falcon67
  • May 27, 2025
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2025
horse sence
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
