Engine oil problem 2002 gt 46l 2v
newtofords
Vancouver WA
got this problem my 2 valve 4.6l oil pressure went from pressure on the gauge to 0 now it does it when u start the eng up good gauge pressure then goes to 0 if u let it sit 2 to 3 mins it start the eng again it has good pressure on the gauge then after a minute it will go to 0 i replaced the oil pressure sensor and oil filter still the same affect doesnt seem to have oil going to the head looking thru the oil cap friend said it could be a clogged screen in the oil pan on the pick up could it be that???? and im not getting any eng codes
  • Sponsors(?)
tsemmett
208
29
38
37
US
Would probably be worth hooking up a legit oil pressure gauge; the factory ones are nothing more than a switch (it's either "Normal" or off essentially), and are really not that trustworthy for diagnosis.
wmburns
SN Certified Technician
Aug 14, 2009
5,838
505
194
Houston Texas
The oil pressure sender can and do go bad. I recently had an "event" on my 2000 GT. The oil pressure fell to zero. Quickly pulled over and checked the oil level. OK. Restarted the motor and there was no valve noise of any kind. I figured it was the oil sender so I drove to the auto parts store for a new one.
Once at home I found that the old sender had an oil leak out the back by the electrical connector. Replaced for a fix.
The part is cheap enough and easy enough to replace for pure diagnostic reasons. One of the few times I will actually recommend "part changing".
Thread starter Similar threads Forum Replies Date
D Oil pressure problems 1994 - 1995 Specific Tech 2
P Engine Oil Pressure Gauge Problems Fox 5.0 Mustang Tech 2
M Engine Oil, Smoke, Fire And Brimstone. Fox 5.0 Mustang Tech 5
M New Guy With An Oil Problem Classic Mustang Specific Tech 27
cmerk27 Engine Very Strange Coolant Leak (checked All The Basics) And Other Problems SN95 4.6L Mustang Tech 21
J 98/3.6 Problem Starting Warm. Oil And Idle Bounce While Idle. 1996 - 2004 SN95 Mustang -General/Talk- 1
S Engine Oil Pressure Problems 1994 - 1995 Specific Tech 9
805mustang Engine Oil In Intake From Pvc .....how To Correct Problem! Pvc Delete? 2005 - 2009 Specific Tech 6
1989fiveohman mystery oil pressure problem Fox 5.0 Mustang Tech 25
JCode95 Oil Dipstick Problem 1994 - 1995 Specific Tech 7
Benboi92GT Oil Pressure Problem?... Fox 5.0 Mustang Tech 11
SGT_Schmidt Oil Problems? SVT Tech Forum 1
MUSTANG J No oil pressure problem solved :) 1974 - 1978 Mustang II Talk & Tech 0
T 87 5.0L SD oil pressure problems???? Fox 5.0 Mustang Tech 3
joel3431 OK, Problem with oil pressure.. HELP!! SN95 4.6L Mustang Tech 5
D 96 mustang gt low oil light problems SN95 4.6L Mustang Tech 3
J intake/oil leaking problem Classic Mustang Specific Tech 9
J new edelbrock intake problem water in oil Classic Mustang Specific Tech 15
CaliStang27 Oil Pressure Problem SN95 4.6L Mustang Tech 4
Z Coolant in oil problem 1994 - 1995 Specific Tech 6
A oil problem 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
S AHH NEW PROBLEM, LOW OIL PRESSURE Fox 5.0 Mustang Tech 11
stanGRR oil pressure problems Fox 5.0 Mustang Tech 2
ttopstang Oil pressure wiring problems Fox 5.0 Mustang Tech 1
C Oil Pan problems Fox 5.0 Mustang Tech 2
S oil problem 1996 - 2004 SN95 Mustang -General/Talk- 3
S oil problem SN95 4.6L Mustang Tech 8
V Oil pressure problem... SN95 V6 Mustang Tech 6
B rebuilt 302 oil pressure problem. need help!! Fox 5.0 Mustang Tech 12
R oil pressure problems Fox 5.0 Mustang Tech 4
D oil pressure problem Fox 5.0 Mustang Tech 7
M Oil Change Problem SN95 4.6L Mustang Tech 14
8 Oil Pressure Problems Fox 5.0 Mustang Tech 5
Brandon11010 Problems Priming Oil Pump Fox 5.0 Mustang Tech 8
C Oil pump pressure problem Fox 5.0 Mustang Tech 1
Jaym14 PCV oil problems - Help please Fox 5.0 Mustang Tech 34
95cbr331 oil pressure problems Fox 5.0 Mustang Tech 2
85_SS_302_Coupe Ever have problems getting the oil pump shaft out? I've got your hook up... Fox 5.0 Mustang Tech 7
Adam95GT Oil Pan Problems Help ASAP!!! 1994 - 1995 Specific Tech 4
R Hose problem - Oil Leaking out SN95 4.6L Mustang Tech 7
S oil leak: could this be the problem? 1994 - 1995 Specific Tech 7
Leanz Oil Pressure problems. SN95 V6 Mustang Tech 12
Foxy2.3TC oil pressure problem 2.3L (N/A & Turbo) Tech 8
D Problem priming oil pump Fox 5.0 Mustang Tech 3
DarkoStoj someone bought my car and is having problems with the axle leaking oil...need info Classic Mustang Specific Tech 49
mob oil pump problem? How to get it out Fox 5.0 Mustang Tech 3
6 oil circulation problem Classic Mustang Specific Tech 1
blckstng96 oil pump shaft problem,HELP!!! Fox 5.0 Mustang Tech 18
PacificStang46 Cam gear oil problem SN95 4.6L Mustang Tech 1
Sinister SN95 Vortech Supercharged guys here.... Having Oil problems still... SN95 4.6L Mustang Tech 14
