Oil Pump Gasket?
I am getting ready to install my oil pump on my explorer 5.0. Shoulg I use rtv on the gaskets that came with the pump or should I just use plain gasket?
The 2 gaskets are for the pump to block and pump and pick up tube.
Thanks,
Whatever you do with the gaskets, make absolutely sure that they have clean metal to seat against. Poor cleanup with leftover pieces of gasket still stuck to the mating surfaces are the primary reason that gaskets leak even when the bolts are properly torqued down. Don't use RTV as a substitute for properly cleaning the mating surfaces: it won't work.
