- Jun 28, 2011
- 18
- 0
- 1
Asking this as a separate thread, since I'm thinking about doing this tomorrow, and my post about my low oil pressure is an essay that some won't slog through.
Basically, I rebuilt an engine, and the oil pressure is not nought (I think/hope/pray), but is very low. From the oil idiot light flickering, around 6psi @2500rpm. My sunpro gauge reads 0psi, but it's also being fed with 10V and not 14V, so it won't read right anyway.
Lots of upper engine noise as a result, the lifters never pump up to take up the slack.
Here's what I'm wondering... because i had left out the driveshaft on initial installation 2 months ago (it's been an on/off project), I had to drop the oil pan and R&R the pump in order to get the driveshaft in there.
I didn't get the pan out: my method to save time was to crank the engine up 5 inches, drop the pan 5 inches, giving enough room to undo the 4 bolts to pull the pump, put in the shaft, reinstall.
I didn't leave a gasket or a bolt lying on the work bench.
Just guessing from my own strength and comparing to times I've used the torque wrench and deducting for the awkward working position, I probably put 15 lb-ft of torque on the bolts that hold in the oil pump. I don't remember that there were ever lock washers on those bolts.
Is there any way a gasket might have blown out, or a bolt worked loose, and it's pissing oil right at the pump?
I've a friend who works at a dealer, and they can work on their own cars after hours. I'm considering having it towed there, and we'll R&R the pump a second time and see what's up. If I find the pump hanging a little loose, a bolt in the pan, a gasket blown out, then I have my answer and might even be able to drive the car away tomorrow night.
But if it's very hard to screw up the pump, then I'll be paying for a tow to the shop and a tow away again, wasting $130 on a red herring.
Also wondering if I do this over, if there are any other procedures to be aware of, like if the bolts need more torque than I gave them, or lock washers, or if I want sealant on the gaskets, or should pack the pump with vaseline to prime it? (I just poured oil in and turned it a few times to prime it)
And what's the proper way to set the little retaining umbrella on the driveshaft? I think it was just about 1.5" down from the top, something kinda random.
